Fast flash LED turn signal
Old Mar 19, 2006 | 02:49 PM
cb21983's Avatar
cb21983
So I know that when I remove the stock turn signals on my bike and replace them with LEDs that my lights are going to flash fast due to the reduced load. Does anyone know what type of resistors I need to put in line so the flashers will operate normally.
Old Mar 19, 2006 | 05:19 PM
jschmidt's Avatar
jschmidt
You can also go to the auto parts store and find a flasher that doesn't have the burnout warning feature. The reason your flasher ticks so fast is that it has this feature and thinks the led is a burnt out bulb.
Old Mar 19, 2006 | 06:51 PM
not to thread hi-jack but...
will those flashers fix the same problem i'm having with my intregrated rear turnsignals / brake lights. they only increase in speed when the brake is applied.
Old Mar 19, 2006 | 07:15 PM
Harry_w's Avatar
Harry_w
Re: Fast flash LED turn signal
The resistors would be about 20 ohms or so, but need to be at least 20 watts running from the hot lead of the light (+) to ground to simulate a lightbulb. Problem is that these resistors will get really hot so you need to mount them against metal if possible to transfer some of the heat from the resistor to the metal. Plastic will melt. Once the weather gets a bit warmer, I will be installing an electronic flasher and that will take care of the fast flash without using a load resistor. Only problem is the Honda flasher has the connectors in a linear line and the flasher I bought is in a triangular pattern so have to make up three leads with connectors on them and mount the new flasher.
Old Mar 20, 2006 | 10:09 AM
thegreep's Avatar
thegreep
If you can help it do not use resistors. . too much heat. I got the tip from CNI Dawg and I bought this:
http://www.cyclegear.com/spgm.cfm?L1...tem=MRX_FRH1_G
Money well spent. it's time based rather than resistance based. You will have to check your lights once in a while to make sure one hasn't gone out, but that's the price we pay.
Old Mar 20, 2006 | 01:57 PM
cb21983's Avatar
cb21983
I think I am going to have to get that flasher with the different flash programs. That would be way to cool.
Old Mar 21, 2006 | 10:43 AM
SuperLoud's Avatar
SuperLoud
The instructions that came with my integrator said that they are supposed to flash fast when you apply the brakes.
Old Mar 21, 2006 | 05:59 PM
cb21983's Avatar
cb21983
So here is what I got and I will have some pictures up as soon as I get finished with the install.
Front Turn Signals
Rear Turn Signals
Trick Flasher
I have already mounted the rear signals and tonight Iam going to finish with the front. The trick flasher should be at my house by Monday.
jaconrad15
Jun 30, 2014 04:03 PM
Onsto
Nov 19, 2009 10:24 AM
salmanilla2000
Oct 6, 2008 08:43 PM
handkaudio
Jul 20, 2008 07:29 AM
Shmittay
Feb 24, 2006 07:20 AM
