LED Lights
Old Sep 9, 2006 | 03:24 PM
PHPERFORMANCE's Avatar
PHPERFORMANCE is on a distinguished road
LED Lights
I just got my tail section done.it had the hotbodies undertail to start.i didnt like how dim the lights were.so i decided to brighten it up with a 1000rr led taillight.i also used the front leds for a 1000rr.just wondering what you guys think?THE LIGHTS ARE WAY BRIGHTER NOW! Has anyone used the flasher from clear alternitives to slow the rate down?
Old Sep 11, 2006 | 09:21 AM
RVO27's Avatar
RVO27
Thumbs up
Looks good! I used the Custom Dynamics Trick Flasher to fix my blinker problems after I changed my rear tail light to a LED light. The Trick Flasher also has some cool blinker patterns that are changable from the turn signal switch so there's no messing around with dip switches or removing anything to change the pattern. Here's the link:
http://www.customdynamics.com/trick_flasher.htm
Old Sep 11, 2006 | 09:56 AM
Thanks, Was It Just A Plug And Play,or Did You Have To Splice?
Old Sep 11, 2006 | 08:13 PM
Funny you should ask. I'm selling the VFX Running light kit with resistors to slow down the rate for $20. These will turn your 2-wire LED fronts into 3-wire with running lights. Dunno if that's what you want or not. Alternatively, you can wire in a resistor of sufficient wattage and resistance to slow the rate. Something low resistance, like about 1ohm, and current must be about 20W, as the stock bulbs are 23W.
Oh, you wire the resistor in PARALLEL with the signal.
Old Sep 11, 2006 | 08:18 PM
RVO27's Avatar
RVO27
It was plug and play. Easy as Pie
Old Sep 11, 2006 | 09:13 PM
SillyHawk's Avatar
SillyHawk is an unknown quantity at this point
hey man nice lights!! thats front SS line looks a little tight...sorry couldnt help but notice
Old Sep 19, 2006 | 07:14 PM
it just looks tight in the photo. look at the head on pic.
rafbo
Jan 3, 2019 02:38 PM
twistidd
May 25, 2012 02:50 PM
theosagekid
Jan 22, 2012 01:33 PM
Pitt3265
Sep 6, 2009 12:59 PM
SuperMike
Jul 14, 2008 05:27 AM
