New member, couple ?s
Old Jul 25, 2012 | 10:51 PM
supersqacky's Avatar
supersqacky is on a distinguished road
Hey everyone! Im glad to finally be a member. Amazing site yall have. Thats right, Texas redneck here!
Heres what I have, 2001 hawk with around 14k on her. Just got out of storage from over a year (I know, I know. Life happens tho) so i gotta clean the carbs out yay.
I need to know what all you seasoned pros think I need to do. Obviously CCT from what ive been reading...what else? Is the PAIR removal worth doing? Any other ideas for making it better?
And lastly, this beast was running awful hot last time I rode her. Remember its Texas so 100 degrees plus happens all summer and I ride aggressive, but I recall hitting 230 and even 235 on the temp gauge many times. Is that normal???
Thanks guys, proud to join the pack!
Old Jul 26, 2012 | 12:10 AM
Yes, 235 is quite normal... I'm running close to that here in Sweden... And it's not Texas heat...
When the display starts blinking it's hot... Until that happens all is well...
Old Jul 26, 2012 | 04:33 AM
Flush and bleed the brakes and clutch.
and other then normal checks, oil, tires, chain, brake pads.. go ride it.... remember what you dont like or what to change,,, then tell us and we will help you spend money.
Where in TX you at? I may be able to REALLLLY help you spend your money..
Old Jul 26, 2012 | 07:41 AM
E I'm in fort worth.
Thanks tweety.
Mostly worried about that tensioner as I remember some chatter that I was thinkin was valve clearance until I found yall. Just wondering if I should fix it while I have carbs off?
Old Jul 26, 2012 | 07:48 AM
Sawzall86's Avatar
When in doubt, C4
Sawzall86 is on a distinguished road
Thanks tweety.
YES!
It's easier to do while they're off since you should pull the rear cam cover to make sure your timing is set correctly. I installed my rear first after making sure I was on rear TDC and locking the cam chain with zip ties to the cam gear. Then you can install the front since you have the carbs out of the way and it's a straight forward procedure. I did the pair removal also since I didn't really like the decel popping.
Old Jul 26, 2012 | 08:39 AM
Anytime you can make the most of working on the bike, I do... I like wrenching and MOD'ing what I drive and ride.... but I like Riding and driving more.
YES replace the CCT now while you have the tank and carbs off.
Old Jul 26, 2012 | 09:27 AM
Where can I get the new CCTs?
Old Jul 26, 2012 | 09:29 AM
Wicky's Avatar
http://www.kriegercamchaintensioners.com
https://www.superhawkforum.com/forum.../klx678-12445/
Old Jul 26, 2012 | 09:41 AM
APE
CBR ZONE
Old Jul 26, 2012 | 09:49 AM
Originally Posted by Wicky
I keep getting a network error for that address...You?
Old Jul 26, 2012 | 10:38 AM
Went right to the website for me. I'm using Chrome.
Old Jul 26, 2012 | 10:43 AM
Works for me too...
Old Jul 26, 2012 | 12:06 PM
HRCA#1's Avatar
SuperdutyD on the forum also makes and sells pair block off plates and Manual Cam Chain Tensioners and he is cheaper than anybody and the stuff is good!
Old Jul 28, 2012 | 07:01 AM
RWhisen's Avatar
Former Superchicken Owner
E I'm in fort worth......
Let me know if you need some help as I am in Ft. Worth too.
Rollin20z
Jan 28, 2013 02:42 PM
barncat
Aug 4, 2012 06:15 AM
WildmanVTR
May 2, 2010 11:04 AM
SlimJimmy
Aug 25, 2006 05:22 PM
Yardstick
Mar 16, 2006 12:30 PM
