ignition coil help
Old Apr 5, 2010 | 12:27 PM
twidge's Avatar
twidge is on a distinguished road
Question ignition coil help
hi folks i,ve had my 99 firestorm in bits all winter [contiuing the streetfighter build] and am putting it back together again.... trouble is i forgot to lable which wires go to the coil for the front cylinder and which go for the coil for the rear cylinder. i have green and a yellow for one and a green and a blue for the other..does it matter which goes to which as i understand it has a wasted spark anyway?
thanks folks.
Old Apr 5, 2010 | 12:55 PM
4bangeranger's Avatar
4bangeranger is on a distinguished road
i will look at mine as soon as i get to my shop
Old Apr 5, 2010 | 04:08 PM
maverick's Avatar
Nope you should be able to hook them up however you'd like.
Old Apr 5, 2010 | 05:30 PM
actually they need to be on the right cyl. just because it is a wasted spark set up doesn't mean it fires on the other cyl. compression stroke.... I'll look the next time I'm out there or check the wiring diagram in the service manual.
Old Apr 6, 2010 | 11:14 AM
twidge's Avatar
Question thanks for the help
thanks for your help folks but i have looked at the wiring diagram in the manual and all it shows is the wires going to the coils but not defining which is which.
Old Apr 6, 2010 | 11:35 AM
Well take another look......
Ignition Coils:
#1 RR (rear) G & Y\Bu
#2 FR (front) G & Bu\Y
Old Apr 6, 2010 | 11:59 AM
twidge's Avatar
Talking many thanks
many thanks 8541hawk.
my manual still dosent show which is which. but again many thanks for your help. i,ll go back in the garage now.
Old Apr 6, 2010 | 12:30 PM
No worries and mine shows it on the main wiring diagram (20-1)
98VTRrider
Nov 13, 2010 04:49 PM
maverick
May 19, 2009 06:26 AM
skoshere
May 6, 2009 09:39 AM
finepooch
Aug 14, 2008 04:32 AM
Markrs1980
Apr 21, 2005 08:58 AM
