ignition coil help
hi folks i,ve had my 99 firestorm in bits all winter [contiuing the streetfighter build] and am putting it back together again.... trouble is i forgot to lable which wires go to the coil for the front cylinder and which go for the coil for the rear cylinder. i have green and a yellow for one and a green and a blue for the other..does it matter which goes to which as i understand it has a wasted spark anyway?
thanks folks.
thanks folks.
actually they need to be on the right cyl. just because it is a wasted spark set up doesn't mean it fires on the other cyl. compression stroke.... I'll look the next time I'm out there or check the wiring diagram in the service manual.
