welding exhaust?
Old Aug 14, 2010 | 03:25 PM
uchi's Avatar
welding exhaust?
ive got a problem, my exhaust needs to either have some real big rivets put into it or i need to tack it or something. the holes have worn and the thing moves around alot. its a jardine sp1 exhaust, can i weld the body to the end cap or is it aluminum or what? i havent checked yet and im too tired to go and look right now from todays track day but id like some input on fixing it.
Old Aug 14, 2010 | 03:41 PM
Well the sleeve should be Aluminum and the end cap is Stainless so you won't be able to weld them.
Old Aug 14, 2010 | 03:56 PM
uchi's Avatar
terrible. what are my choices short of getting really big rivets?
Old Aug 14, 2010 | 04:14 PM
RWhisen's Avatar
Former Superchicken Owner
Your only real choice is some blind rivets but you have to be careful and get the correct grip length and head size as well as the correct shank diameter. You have to use blind rivets or "pop-rivets" since you can't get to the back side of it to put a bucking bar on and swell the rivets as they are hammered. Make sure you get the closed end style so you don't have leaks.
http://www.rivetdirect.com/closedendrivets.html
Old Aug 14, 2010 | 09:35 PM
uchi's Avatar
so much info, thanks buddy. it may just be easier to cut half an inch off the pipe and redrill it, lol.
Circuit_Burner
May 30, 2009 06:45 PM
SlowHAWK
May 21, 2009 05:15 PM
11strings
Feb 12, 2009 06:58 PM
trackdayhawk
May 23, 2008 03:44 AM
NOrrTH
Nov 17, 2005 07:47 PM
