Torque specs on right engine crankcase/clutch case cover
Old Apr 2, 2005 | 12:54 PM
StuDaddy's Avatar
StuDaddy
Hey fellers...
I posted this question in the tech discussion forum, but didn't get any response... sorry for posting twice, but I'm planning on doing the work tomorrow (if it ever stops raining )
Hopefully one of y'all has a service manual and can look up this info for me.
I'll be installing the right side crankcase cover this weekend, but I don't know the torque specs. Any help is appreicated.
I just thought of something else... will I be able to get a short socket on the bolts? If I have to use an extention, what do I have to change on the torque wrench to adjust for the extention?
Also, if there's anything else I need to know, please throw it out there. I'm hoping it's a pretty straight forward job (drain oil, remove old cover, clean gasket goo off, replace w/ new gasket and casecover, torque to spec, fill w/ new oil) Anything else?
Old Apr 2, 2005 | 01:53 PM
marmaladedad's Avatar
Hmm?
I'm not sure what part the crankcase cover is, but looking at my service manual, it says:
Crankcase 10mm flange bolt - 39N*m or 29lb-ft
Crankcase 10mm special bolt - 42N*m or 31lb-ft (Apply oil to the threads and seating surfaces)
HTH
Oh, and is that right about the torque wrench? That if you use an adapter, the numbers will be off?
Old Apr 2, 2005 | 02:05 PM
StuDaddy's Avatar
StuDaddy
Re: Torque specs on right engine crankcase/clutch case cover
Here's a picture of the cover... it's the engine cover w/ the oil fill hole and oil level sight window.
I'm just going by what I was told re. the extention.... was someone BSing me?
Damn I wish the bike was right outside (it's at my parent's house about 20 minutes away).... i could just go out there to see what the hell they're talking about when they say "flange" and "special" bolt
Thanks for the quick help!!!
Old Apr 2, 2005 | 05:00 PM
Hmm?
I'm having trouble finding that same picture in my service manual.
The specs I gave you are incorrect for the picture and descriptions you gave to me. Sorry!
I'll keep digging through my manual to see if I can find what you're looking for.
Old Apr 5, 2005 | 07:18 PM
call me phil's Avatar
call me phil
in the general disscussion area there is a thread about a downloadable service manual, i checked it out and its ok and it had everything in it! hope this helps
Old Aug 14, 2010 | 06:47 PM
brandondrac's Avatar
brandondrac is on a distinguished road
help plez
l
Old Aug 14, 2010 | 08:13 PM
Well that is usually referred to as the clutch cover and there is no torque spec listed in the manual for those bolts. So just tighten them down kind of tight and you will be fine.
Old Aug 15, 2010 | 09:26 AM
mboe794's Avatar
I usually go to 7 or 8 ft. lb. on those little 6mm bolts.
jscobey
Apr 30, 2014 06:47 PM
CrickiKaze
Mar 19, 2014 12:06 AM
vtrider
Aug 20, 2008 11:57 AM
quakefiend420
May 19, 2007 12:44 AM
StuDaddy
Mar 28, 2005 04:58 AM
