Twingle
Old Jun 2, 2019 | 05:07 PM
ACE VenTRa's Avatar
Twingle
I was BS-ing with a flat tracker I know and he said that back in the day the Harley guys developed what they called a "Twingle." He said that he couldn't remember off hand how they did it, but that there was more than one way and essentially they set crank/cam/ignition timing in such a manner that both cylinder fired at or nearly at the same time. Apparently they made massive torque and kicked *** in flat track. He couldn't recall any 90 degree twins having been set up that way, but it got me thinking as a fun project. anyone have any thoughts on Twingels?
AV
Old Jun 2, 2019 | 05:30 PM
You need to set your cam timing out 180 degrees on one cylinder (not sure about how to do it with ignition, however) and you will end up with a 90-630 firing interval instead of the habitual 270-540. Doing so will likely end up starving the engine for air at high rpm as the close firing order is not providing sufficient time for the airbox to replenish its supply of fresh air. For kicks, do a Google search on the Aprilia MXV450 (likely works for SXV/RXV 450 and 550 too) as some configured its 77-deg V-twin to run this way
BTW, check the vtr1000.org site for additional info about this as some have inadvertently created a "twingle" from the VTR
Old Jun 2, 2019 | 06:09 PM
Honda big bang engine from Moto GP.
Old Jun 3, 2019 | 02:24 AM
ACE VenTRa's Avatar
Now I see, that could be kinda fun. i bet the hawk would sound pretty good that way.
Old Jun 3, 2019 | 04:12 AM
Wicky's Avatar
There was a VTR1000.org member who inadvertantly ran his storm 180° out for a couple of years - it only came to light when it was dynoed ;-) Apparently it ran ok apart from hitting a barrier over about 7000rpm... (carb tweaks got it 9k)
vtr1000f/99
May 11, 2012 09:49 AM
Rama
Dec 8, 2011 11:56 AM
superchickencornermonster
Sep 26, 2011 06:29 AM
Billzilla15
Aug 23, 2010 12:12 PM
Babelfish
May 30, 2007 10:43 PM
