BIKE DIES WHEN IDLING
Old Jun 7, 2019 | 03:10 PM
wheels's Avatar
wheels is on a distinguished road
Hey guys thanks for all your help I am now riding the theft recovery bike ,Occasionally when sitting at a light bike will die ,but will immediately restart ? any ideas carbs are spot on runs flawless
Old Jun 7, 2019 | 04:40 PM
YMRacing's Avatar
Idle set properly?
Old Jun 7, 2019 | 06:18 PM
Wicky's Avatar
Carb fart - up the idle a tad more to help avoid it also stalling in slow turns.
Old Jun 8, 2019 | 05:04 AM
wheels's Avatar
will double check idle and raise it a little thanks
Old Jun 8, 2019 | 11:05 AM
Aquasnake's Avatar
Correct idle setting, carb sync, check tps setting.
Adjust each as needed.
Old Jun 8, 2019 | 11:07 AM
CaryDG's Avatar
I've also found that carb synchronization is most critical at idle as well. You may want to; adjust your fuel mixture screws to baseline, sync your carbs, adjust your TPD to 500ohms, then set your idle to 1150rpm, or so.
Or, you can just up the idle and ride.
Old Jun 8, 2019 | 11:09 AM
CaryDG's Avatar
Aquasnake, you beat me 2 minutes. LOL
Old Jun 10, 2019 | 11:37 AM
wheels's Avatar
had idle set too low 1000 rpm
Old Jun 10, 2019 | 03:17 PM
YMRacing's Avatar
FWIW, I never use the vehicle's tachometer to set an idle. While the old dwell/tach combo meter is outdated, it gives me a better idea of the actual idle. e.g. my TransAlp shows 1500rpms on the clock when it is set at 1100 rpms on the dwell/tach meter. If I set it by the clock...it would be too low.
Old Jun 11, 2019 | 04:47 AM
For me I got the fuel mixture screws and richened the fuel mixture to the point that I nearly eliminated the carb fart/ stutter thing completely.
You may have to clean the idle/slow speed jets to help that too.
Old Jun 11, 2019 | 06:05 AM
wheels's Avatar
I have richened it lol and will use a digital tach to set idle
ZERO
Jan 20, 2015 06:12 AM
turbotim
Jun 18, 2010 12:53 PM
pzurek18
Oct 25, 2009 01:47 PM
VoodooDog
May 16, 2007 01:18 PM
FRANKSVTR
Apr 27, 2006 08:37 PM
