Timing Help
Old Aug 20, 2010 | 06:52 AM
Billzilla15's Avatar
Timing Help
ok, so does anyone else think that the way to set the timing on the hawk is one of the dumbest thing ever?
i recently upgraded to manual ccts, after doing it the wrong way and having both cylinders jump timing, ive reset them to what i think is right however, the rpms break up at about 7.5 8k and on decel i get noticeably more backfiring,
so first is there any insight to this,
let me tell you what i have
*clean air filter - stock, but not new
*shortened 2 bros exhaust (cut about 10 in. out of each)
*compression - 165 front and 163 rear
*new ngk iridium ix plugs
*never removed anything past the air box, never touched the carbs i did unplug the tps but never removed it
* ape ccts, set tension the new way by measuring deflection in the chain
so, i'm wondering if you have any suggestions or if theres a easier way to set the timing than what the service manual calls for
thanks in advance
Old Aug 20, 2010 | 08:17 AM
RCVTR's Avatar
The method in the manual is the way you set the cam timing.
I suggest removing the valve covers and recheck.
Old Aug 20, 2010 | 08:23 AM
done it, like 3 times the last time i set them, i actually guessed a tooth off from what looked right and it ran better if that makes any sense
Old Aug 20, 2010 | 08:38 AM
RCVTR's Avatar
I forgot to mention the part about the TPS.
did you leave it unplugged? If so, why?
the ECU uses throttle position with RPM to set the ignition timing, from the lookup table.
Old Aug 20, 2010 | 08:44 AM
i had unplugged to to take one of the pair lines off but i plugged it right back in do i need to reprogram it because it was unplugged for a minute
Old Aug 20, 2010 | 08:54 AM
RCVTR's Avatar
No, you will be fine, there.
I'm starting to think you have a vacuum leak. It would cause a lean condition and backfiring on decel.
Check your vaccuum lines and be sure you have blocked off the PAIR vacuum.
Old Aug 20, 2010 | 09:32 AM
the little vacuum line at the top of the pair valve was off, im going to reassemble the bike and report back
Old Aug 20, 2010 | 09:46 AM
fixed the backfire, still got the flat spot, going to check the riming on the front cylinder again, its the one i changed the intake timing on, ill be back
RCVTR thanks youve been a huge help
Old Aug 23, 2010 | 12:07 PM
ok, so the timing is set dead on, and i still have the rps breakup past 7k any idea as to what would be causing this
Old Aug 23, 2010 | 12:10 PM
Have you checked the petcock diaphragm?
Old Aug 23, 2010 | 12:12 PM
no, i haven't is there a way to do that?
tromo01
Jul 30, 2009 05:08 PM
mattvdsande
Mar 16, 2009 11:12 AM
superchicken
Dec 13, 2007 11:50 AM
cliby
Mar 1, 2007 09:55 AM
ATLSHawk98
Jan 5, 2007 08:22 PM
