Throttle Lock
Old Mar 1, 2008 | 10:51 AM
Jeepingoose's Avatar
Jeepingoose is on a distinguished road
Throttle Lock
Anyone use or have a throttle lock for thier SH?
I had a makeshift one for my EX500 when I first started riding, and for long trips it was very nice to be able to stretch out and flex your right hand.
Plus, its good for doing stupid stuff too
So anyone know where I might find one for my 99?
Thanks!
Adam
Old Mar 1, 2008 | 11:03 AM
RickB's Avatar
I have one on mine, Vista Cruise model I believe.... dealers have them and you can search on google or your favorite search engine to find sites that have them. I suppose you could do some "stupid stuff" with one if you really wanted to...
Old Mar 1, 2008 | 11:12 AM
I like to lock the throttle and slide back onto the rear seat and ride that way sometimes
Old Mar 1, 2008 | 11:26 AM
What size are the bars?
Old Mar 1, 2008 | 12:18 PM
Why do you need a thottle lock in HI? LOL The longest straight road is maybe 10 miles...
I like the NEP (less then $15) but I have XL hands, the small pastic Vista Cruise (not the multi-piece cross bar one), is better for small hands. Then there is the expensive ThrottleMiester and I'm sure a few others.
Old Mar 1, 2008 | 12:25 PM
superbling's Avatar
NEP
Old Mar 1, 2008 | 02:58 PM
HRCVTR1000's Avatar
NEP
+1 , make sure you get the one made specifically for the Honda , its different .
Old Mar 1, 2008 | 03:05 PM
HRCVTR1000's Avatar
Matter of fact this is where I got mine ....http://www.casporttouring.com/thestore/prods/177.html Although they can be found cheaper !
Old Mar 1, 2008 | 03:23 PM
Throttlemeisters are nice, but expensive.
Old Mar 1, 2008 | 03:34 PM
there we go again, read up
Old Mar 1, 2008 | 03:36 PM
Yeah, but you didn't say they were nice.
Old Mar 1, 2008 | 03:40 PM
Here's a pic to make it all better...
Old Mar 1, 2008 | 05:05 PM
Nice Greg
Is the white paint easy to keep clean & scratch-free. Those tank bags that attach to the gas cap ring seem like they put quite a load on the fasteners &/or threaded tank inserts??
I can't afford the Throttle Meister grip lock but have been using the NEP for many moons (i.e., well before my VTR). Note the F4i calipers which are identical to the 00-01 RC51 but black (I painted the fastener heads). Have yet to test ride the Tommis & MP throttle cables, RC51 with the F4i calis, and the longer HEL clutch line. The Russel brake lines go back to day 1 practically.
Attached Thumbnails Throttle Lock-vtr-tommies-lngr-thrtl-cables-grip-swtch.jpg   Throttle Lock-vtr-w-01-rc51-brk-mc-stk-clutch-mc-tommies.jpg   Throttle Lock-vtr-w-01-rc51-brk-mc-tommies-nep.jpg   Throttle Lock-vtr-w-01-rc51-brk-mc.jpg   Throttle Lock-vtr-w-f4i-caliper-r-l.jpg
Old Mar 1, 2008 | 06:50 PM
shawkpilot's Avatar
shawkpilot is on a distinguished road
A buddy of mine uses a rubber O-ring. He stores it on the bar end, and when he wants to use it, he just rolls it over. It kinda wedges between the bar end and the throttle, and adds just enough resistance to not let the throttle go to idle. Very cheap mod, and requires 0 mechanical ability.
Old Mar 1, 2008 | 06:54 PM
Throttlemiesters!
Old Mar 1, 2008 | 07:57 PM
The O-ring trick is old time and can allow rolling on and off but still is somewhat dangerous. Same thing with the throttle set screws on Harleys and other older bikes but I think the attorneys took care of that. Its safer to stick with a true quick-off device as mentioned above.
Old Mar 2, 2008 | 09:14 AM
No, the paint is actually easier to keep clean since you can see where the dirt is. So when the bike is dirty, it's dirty. But when it's clean, it's truly clean.
Let us know how all the brake mods turn out. Looks like you got everything sorted.
Old Mar 2, 2008 | 11:00 AM
I've had one white vehicle (a Honda Odyssy) and it was a pain to keep clean but our VTRs have a lot less surface area (though you have a lower right) and are not out much in the winter.
How many pounds can your tank bag handle? I use an old CH strap-on and Held mag unit, both which take a lot and you can lean on during long rides.
The RC51 MC seems better now that its matched but still firm with little travel (but maybe better feel). After I sanded the OEM F4i pads using 150 drywall grid (to clean and take out the bedding from the previous owners rotors), cleaned my OEM rotors with skotchbrite (I use diluted detergent and ammonia followed by 91% iso alcohol), it bites like a demon. Still I can't wait till spring to road test everything (though its a 45 today but what a mess at the cemetary for my very close aunt's funeral, whe was a stitch).
Old Mar 2, 2008 | 12:43 PM
I see the throttlemeiters, but how does it work? I get the gist of the NEP but unsure how the TM works.
Old Mar 2, 2008 | 12:59 PM
This is from the Throttlemeisters website...
" Once you've mounted the Throttlemeister bar ends to you bike, they work like this... All of the workings of the Throttlemeister are inside the bar end itself. Once mounted, you turn the whole bar end in the same direction as opening the throttle. A piston moves in and out of the Throttlemeister itself and puts friction against the throttle tube which in turn, counteracts the throttle return spring. When installed properly, the Throttlemeister will not completely lock the throttle, you can always override the Throttlemeister in any situation. If you need to stop quickly you can just grab the throttle and turn it off."
Old Mar 2, 2008 | 01:01 PM
suhweet!
Old Mar 2, 2008 | 01:02 PM
Ya not even, more like A mile. But I wont be here much longer God willing! I miss road trips!
Old Mar 2, 2008 | 07:59 PM
Skokie,
I've carried quite a lot with that tank bag. It'll hold 20# easy. I talked to the owner of the company and he said he had a customer test the bag by loading a cinder block (!) in it and ride around. It held up to the torture and no damage occurred to the bike, the bag, or the cinder block ! Usually I don't run that tank bag on the VTR. I have two rings that mount on the tank and one bag. I usually keep the two rings on both CBRs since they both have plastic tanks. The mounting uses three screws and is quick to change out. It's a very secure system.
Old Mar 2, 2008 | 09:09 PM
Skokie,
very impressive. who makes it (just curious as my funds are depleted due to funeral expenses this week and I don't need one anyway)?
Old Mar 3, 2008 | 03:32 AM
Made by Luggage Locker. You guessed it: www.luggagelocker.com
Old Apr 5, 2008 | 02:20 PM
got my throttle lock installed and tested. Im happy, if only to see peoples face when i sit on the back seat of the bike and keep up with them on the road lol
new windscreen and camera mount also up and running now.
Attached Thumbnails Throttle Lock-img_1368.jpg   Throttle Lock-img_1369.jpg   Throttle Lock-img_1370.jpg   Throttle Lock-img_1371.jpg
Tsperez
May 20, 2013 09:36 AM
3amta3
Jun 3, 2011 12:45 PM
Wolverine
Sep 2, 2010 06:03 AM
CentralCoaster
Sep 23, 2008 11:06 AM
Randman
Jun 3, 2007 09:10 PM
