Throttle Lock
Anyone use or have a throttle lock for thier SH?
I had a makeshift one for my EX500 when I first started riding, and for long trips it was very nice to be able to stretch out and flex your right hand. Plus, its good for doing stupid stuff too ;) So anyone know where I might find one for my 99? Thanks! Adam |
I have one on mine, Vista Cruise model I believe.... dealers have them and you can search on google or your favorite search engine to find sites that have them. I suppose you could do some "stupid stuff" with one if you really wanted to... :shock:
I like to lock the throttle and slide back onto the rear seat and ride that way sometimes
What size are the bars?
Why do you need a thottle lock in HI? LOL The longest straight road is maybe 10 miles...
I like the NEP (less then $15) but I have XL hands, the small pastic Vista Cruise (not the multi-piece cross bar one), is better for small hands. Then there is the expensive ThrottleMiester and I'm sure a few others. |
NEP
(Post 154242)
NEP
Matter of fact this is where I got mine ....http://www.casporttouring.com/thestore/prods/177.html Although they can be found cheaper !
Throttlemeisters are nice, but expensive.
(Post 154252)
Yeah, but you didn't say they were nice. :nana: :lol:
1 Attachment(s)
Here's a pic to make it all better...
Nice Greg
5 Attachment(s)
(Post 154255)
I can't afford the Throttle Meister grip lock but have been using the NEP for many moons (i.e., well before my VTR). Note the F4i calipers which are identical to the 00-01 RC51 but black (I painted the fastener heads). Have yet to test ride the Tommis & MP throttle cables, RC51 with the F4i calis, and the longer HEL clutch line. The Russel brake lines go back to day 1 practically. |
A buddy of mine uses a rubber O-ring. He stores it on the bar end, and when he wants to use it, he just rolls it over. It kinda wedges between the bar end and the throttle, and adds just enough resistance to not let the throttle go to idle. Very cheap mod, and requires 0 mechanical ability.
Throttlemiesters!
Originally Posted by shawkpilot
(Post 154264)
(Post 154258)
Is the white paint easy to keep clean & scratch-free. Those tank bags that attach to the gas cap ring seem like they put quite a load on the fasteners &/or threaded tank inserts??
Let us know how all the brake mods turn out. Looks like you got everything sorted. |
(Post 154291)
No, the paint is actually easier to keep clean since you can see where the dirt is. So when the bike is dirty, it's dirty. But when it's clean, it's truly clean.
Let us know how all the brake mods turn out. Looks like you got everything sorted. How many pounds can your tank bag handle? I use an old CH strap-on and Held mag unit, both which take a lot and you can lean on during long rides. The RC51 MC seems better now that its matched but still firm with little travel (but maybe better feel). After I sanded the OEM F4i pads using 150 drywall grid (to clean and take out the bedding from the previous owners rotors), cleaned my OEM rotors with skotchbrite (I use diluted detergent and ammonia followed by 91% iso alcohol), it bites like a demon. Still I can't wait till spring to road test everything (though its a 45 today but what a mess at the cemetary for my very close aunt's funeral, whe was a stitch). |
I see the throttlemeiters, but how does it work? I get the gist of the NEP but unsure how the TM works.
This is from the Throttlemeisters website...
http://www.throttlemeister.com/TMTWIST.gif " Once you've mounted the Throttlemeister bar ends to you bike, they work like this... All of the workings of the Throttlemeister are inside the bar end itself. Once mounted, you turn the whole bar end in the same direction as opening the throttle. A piston moves in and out of the Throttlemeister itself and puts friction against the throttle tube which in turn, counteracts the throttle return spring. When installed properly, the Throttlemeister will not completely lock the throttle, you can always override the Throttlemeister in any situation. If you need to stop quickly you can just grab the throttle and turn it off." |
suhweet!
(Post 154240)
Skokie,
I've carried quite a lot with that tank bag. It'll hold 20# easy. I talked to the owner of the company and he said he had a customer test the bag by loading a cinder block (!) in it and ride around. It held up to the torture and no damage occurred to the bike, the bag, or the cinder block :lol:! Usually I don't run that tank bag on the VTR. I have two rings that mount on the tank and one bag. I usually keep the two rings on both CBRs since they both have plastic tanks. The mounting uses three screws and is quick to change out. It's a very secure system. |
(Post 154332)
Skokie,
Made by Luggage Locker. You guessed it: www.luggagelocker.com :mrgreen:
4 Attachment(s)
got my throttle lock installed and tested. Im happy, if only to see peoples face when i sit on the back seat of the bike and keep up with them on the road lol
new windscreen and camera mount also up and running now. |
