Theres fuel draining out my exhaust
Old Jul 6, 2014 | 11:01 PM
Thtkiddjj92's Avatar
Thtkiddjj92 is on a distinguished road
Can someone help honestly idk what to do there gas some how comeing out of my exhaust pipe
Old Jul 7, 2014 | 01:52 AM
Vacuum petcock failed or blocked open.
Carb float valve(s) got old and either stuck open, got a bit of dirt in there or sometimes they just wear out and fail.
Carb overfills, dumps fuel into intake port.
Open valves lets the crank case and exhaust system fill with fuel.
You will need to check the petcock. Clean or replace the float valves.
Drain the oil and change it and the filter.
Remove and drain the exhaust or let it sit long enough to evaporate but if it is full enough to drip out you might want to pull it so you don't start the bike with a load of fuel still in there.
Old Jul 7, 2014 | 10:15 AM
wyldryce's Avatar
...and bend a rod
CruxGNZ
Apr 29, 2013 03:56 PM
Unzie57
Oct 22, 2012 06:30 PM
Super-Rob
Jul 30, 2010 10:08 AM
05xman
Sep 22, 2007 06:40 PM
bowhawk
Jul 14, 2007 11:12 PM
