Tensioner pads/caps
Old May 3, 2020 | 12:23 PM
G6tech's Avatar
G6tech is on a distinguished road
Tensioner pads/caps
Last summer my vtr jumped time and ate the front intake valves. Flash forward and I’ve purchased a used engine to install, with yosh cams and new tensioners, but when I removed the tensioners, both of them were missing the pad/cap that Honda shows in the parts diagram. On my blown engine, the front was missing but the rear was there. Anyone else have experience with them not being there from the factory or have I purchased a sh*t motor?
Old May 3, 2020 | 01:57 PM
Wicky's Avatar
They can get stuck when the tensioner gets pulled. Or a PO forgot to put them on when installing CCTS. Shine a torch down the hole / check the oil pan.
Old May 3, 2020 | 02:42 PM
YMRacing's Avatar
Then replace them with Manual CCT's.
Old May 3, 2020 | 02:46 PM
G6tech's Avatar
I shined a light down before ever pulling them. Not there. Ordered them on eBay today, local Honda shop is pretty slow on getting parts.
I don’t like manual tensioners on a street bike, require to much adjustment. If these were easier to get to like a modern 4 banger then maybe, but still probably unlikely.
Old May 3, 2020 | 02:53 PM
Your welcome to not like them, but your greatly mistaken for your reasoning.
38k on my 1998 never need to adjust them, 36,328 miles on my 2001 no need to adjust them. and on the other 5 or 6 dozen VTR's I have installed them on they have not needed adjustment.
Add in the few hundred other bikes I've installed MCCT's on and they did not need routine adjustment other than at top end or full rebuild. I think I have a fair bit of personal and professional experience that seems to differ from your cited reasoning.
To each his own, do what works for you.
BTW, keep an eye on part outs or ebay for a front head ...your going to need it running ACCT's
Old May 3, 2020 | 03:18 PM
G6tech's Avatar
i got 63k on acct’s, with 3 years of strictly track use.
I installed manual tensioner on my cbr and it needed adjustment every 10k or so. I ride that or more per year.
Old May 4, 2020 | 04:32 AM
Seems you have more CCT failures using ACCTs then I have on my personal VTR's or those I work on running MCCTs
To each his own, do what works for you..
Id rather lose a repair job and help a customer keep their bike running then hold information that can save them time and money. And the same goes for sharing info here.
If you understand they commonly fail, that its a known issue and that manuals dont fail (improper install of them does cause failure ), and rarely if ever need adjustment in normal use...That said, if you want to use ACCT's, well to each his own, I do wish you many trouble free miles.
Old May 4, 2020 | 07:54 PM
CaryDG's Avatar
Constant adjustment
I don't know Eric, I put MCCT's in my SH 5 years and 35800 hard miles ago and I had to adjust them every....., er…..NEVER!. I used the cam covers off, 5 -6 mm play with 5# of pressure way of setting them up (VTR1000.org). When I replaced mine with some ETL's (camchaintensioners.com/uk)(because I like how they're made, seal, Etc.)they had an additional .5mm play using the same method. In G6tech's defense I have two SH buddies that had differing experiences. Both using fastidious maintenance and high quality oils. One has a '99 and the other an '00. One, the '00, had catastrophic CCT failure at 19k miles the other was using the originals at 42k miles with no problems. Now he has my old Kriegers for piece of mine. As Clint Eastwood said "Do you feel lucky?"
Old May 5, 2020 | 04:32 AM
G6tech's Avatar
Thank you all for helping me answer my question, and for the indoctrination. After removing the oil pan, the caps were not in there, so I'm assuming the previous owner left them out, or Honda never installed them.
Old May 5, 2020 | 03:52 PM
ACE VenTRa's Avatar
While we're on the friendly topic:
Here's a pic of my springs that have been cryo treated and coated with a transition coating to reduce the thermal effect on the spring while baking in the engine:
And here's link to a vid of a guy who re-adjusts his accts in his VFR from time to time as part of maintenance:
AV
Old May 6, 2020 | 04:39 PM
YMRacing's Avatar
What do you charge for a set of treated springs? <=> than a good set of manual CCT's? Not being a smartass, my norm, really would like to know. TIA
Old May 11, 2020 | 07:33 AM
Goose86's Avatar
Goose86 is on a distinguished road
2nd this ^^ I’d be potentially interested...and curious to see if they add longevity and more reliability to the factory CCT’s.
Badboy01
Dec 22, 2018 05:13 PM
inderocker
Oct 7, 2011 06:31 PM
3amta3
Jun 12, 2011 04:20 AM
superchicken
Jul 29, 2007 07:22 AM
Speed_Demon
Mar 14, 2006 10:18 PM
