Superhawk only likes fresh fuel
Old Oct 2, 2016 | 07:27 AM
wrj913's Avatar
wrj913 is on a distinguished road
My 01 superhawk seems to only like fresh fuel from the pump. Even 1 day old fuel seems to perform less than optimum like freshly pumped fuel does. Does the fuel degrade just enough in that 1 day or might something be off in the superhawk?
Old Oct 2, 2016 | 08:06 AM
Some days mine runs great, some days things just don't "feel right". It's NOT the bike, it's me. Maybe that's your fuel issue?
I do know for sure that running third rate fuel for the long term will cause issues. In some of the vehicles I've owned I could tell a difference in how the motor ran right after a fill up with other than my usual gas.
Just some food for thought.
Old Oct 2, 2016 | 08:09 AM
You need to keep your fuel refrigerated @ a cool 53 degrees It's cooler when it comes outta the underground pump, hence your slight increase in performance.
Old Oct 2, 2016 | 08:56 AM
Jack Flash's Avatar
Well take off, eh.
seems
Here lies the key word. The gas is not your problem.
Old Oct 2, 2016 | 09:23 AM
wrj913's Avatar
It seems like the gas. It may be some system on the bike. The hawk accelerates better with fresh fuel than with a couple day old fuel. Fresh fuel performs noticeably better than fuel that has been in the tank a couple days.
Old Oct 2, 2016 | 10:47 AM
Jack Flash's Avatar
Well take off, eh.
Well, if you're so sure it's the gas, then something may be contaminating your gas. Perhaps run a fuel friendly cleaning agent like seafoam or something like that in your gas tank.
I doubt this will solve your issue, however, it will help eliminate potential contaminates in the fuel distribution system.
Old Oct 2, 2016 | 11:12 AM
wrj913's Avatar
This bike has been like this since I got it. But was in **** poor shape when I did. When I first changed the clutch fluid it changed the friction zone on the lever it was that bad. But I have added inline fuel filters and I would put in sea foam or Royal purple with every fill up. But after a day or so it would return to its normal state when I would like to figure out how to keep the power it gets with fresh fuel.
Old Oct 2, 2016 | 11:14 AM
wrj913's Avatar
Hopefully my winter maintenance may fix the issue. Plan to look at the CCT, valve clearances and do a good carb clean/sync. Has roughly 40k miles
Old Oct 2, 2016 | 01:12 PM
superbeater's Avatar
It's not the gas.
Old Oct 2, 2016 | 03:23 PM
thetophatflash's Avatar
Originally Posted by superbeater
It's not the gas.
+1
Old Oct 2, 2016 | 03:32 PM
wrj913's Avatar
Any thoughts to the issue then if it's not the gas?
Old Oct 2, 2016 | 04:39 PM
Fastguy59's Avatar
This is probably the culprit, Wolverine is on the pointy end of this. When I drag raced cars we ran "cool cans" an aluminum can with about 2.5 feet of fuel line in a coil, drop in ice or dry ice presto instant horsepower and throttle response! Mike Velasco (Factory Honda tuner) once built a bike with a second filler in the fuel tank leading to a chamber that they loaded dry ice into... Made the bike faster!
Old Oct 2, 2016 | 06:20 PM
wrj913's Avatar
Originally Posted by Fastguy59
This is probably the culprit, Wolverine is on the pointy end of this. When I drag races cars we ran "cool cans" an aluminum can with about 2.5 feet of fuel line in a coil, drop in ice or dry ice presto instant horsepower and throttle response! Mike Velasco (Factory Honda tuner) once built a bike with a second filler in the fuel tank leading to a chamber that they loade dry ice into... Made the bike faster!
Sounds pretty awesome. Though the only upgrade I can think of to help right now is adding a heatshield under the gas tank again. Would it be that much effective? (Didn't have one when I acquired it, but parts diagrams shows there should be one)
Old Oct 2, 2016 | 06:56 PM
What kind of fuel filters do you have?
Old Oct 3, 2016 | 07:05 AM
wrj913's Avatar
The inline paper filters from oreilly's. Haven't had an issue from them. But the issue happened before I installed them
Old Oct 3, 2016 | 03:08 PM
Fastguy59's Avatar
You can ordercheatsheikd material from CFM Woodcraft, great peeps
Old Oct 3, 2016 | 03:15 PM
Fastguy59's Avatar
Try these Crux, nice quality!
Old Oct 3, 2016 | 06:42 PM
Got 'em!
https://www.superhawkforum.com/forum...filters-32447/
JamieDaugherty
May 31, 2011 06:53 AM
harlangto
Jun 12, 2009 05:10 PM
FL02SupaHawk996
Dec 16, 2007 01:05 AM
Randman
Feb 12, 2007 06:49 AM
moto_man417
Sep 22, 2005 08:18 AM
