Starting bike in gear
Old Mar 4, 2009 | 10:21 PM
VTR Time-Travel's Avatar
VTR Time-Travel is on a distinguished road
Is something broken on my bike 1998 SH or is it normal that I cannot start my bike when it is in gear by just pulling in the clutch. I have to put it in neutral before I can start it.
Old Mar 4, 2009 | 10:23 PM
HawkFanatic's Avatar
HawkFanatic is on a distinguished road
Is your side stand down?
Old Mar 4, 2009 | 10:26 PM
No it is when it stalls out on me and I want to restart it.
Old Mar 4, 2009 | 10:36 PM
Something's wrong with the sidestand switch or your clutch switch. More than likely the connectors came off the swich on your clutch lever.
Old Mar 4, 2009 | 10:51 PM
Thanks I will check both connections and see if one of them fix the probem. It never has worked since I bought it used. It just seemed weird to me that it wouldnt start unless it was in neutral.
Old Mar 5, 2009 | 07:48 AM
Red_Liner740's Avatar
back of the clutch lever there are 2 wire spades....sometimes they slide out...the other place is under the seat next to the battery thats where most of the connectors are...
if both are hooked up, u gotta do more testing...
trace the wires from the handle to the connector in the back pull it back, put a voltmeter across the wires and squeeze the clutch, you should see continuity...if u dont, thats your problem, either the mechanism in the clutch is messed or the wire is broken somewhere.
Old Mar 5, 2009 | 08:15 AM
11strings's Avatar
11strings is on a distinguished road
I had that same problem for a while. I had the start switch off and cleaned it really good. For whatever reason, that seemed to correct the problem. Was it actually related to the problem? Hell if I know, but I can start in gear moving down the road now (if the cold natured beast just decides to puke on me). It's something else you could easily do along with the sidestand switch and the clutch switch. Good luck...
Old Mar 5, 2009 | 04:52 PM
I took the switch off and the clutch handle , cleaned it did a test on the switch put it back together and now it works!!! It has really bugged me to stall at a light and have to put it in neutral before starting, but not anymore. Thanks for the help.
Old Mar 5, 2009 | 09:47 PM
Glad we could help.
CruxGNZ
Jan 13, 2016 07:19 AM
Badboy01
Jul 15, 2015 11:04 PM
Letsrideinsc
Sep 3, 2009 03:16 PM
viperkillertt
Aug 28, 2009 07:13 PM
macworld
Aug 27, 2007 11:36 PM
