Bike not starting, heard a pop from the rear.
Old Sep 3, 2009 | 09:51 AM
Letsrideinsc's Avatar
Letsrideinsc
Hi all,
So I'm running late this morning, so I hop on the chicken, pull choke out turn ignition on, make sure all is good, I hit the starter button and a pop from under my *** and all the lights go out and nothing! I checked all the fuses, all are good. Any ideas? It's been a long time, but This is the second time it has done this to me, the last time IIRC, I let is sit for a minute and tried again and it fired, WTF??? Is this a RR issue?
Thanks for any input.
Old Sep 3, 2009 | 10:10 AM
Well... Have you checked the main fuse and the R/R then?
Old Sep 3, 2009 | 10:15 AM
Letsrideinsc
Nope, I was in a rush out the door, had to hop in the truck. Does the R/R have a fuse attached or is there a way to tell it's bad? I didn't check the main fuse, where is that one? Like I said I was in a rush and didn't have time to go through it thoroughly.
Old Sep 3, 2009 | 10:54 AM
The main fuse is under the rear cowl opposite from the R/R... No fuse by the R/R, but if it popped, it will most certainly look and smell damaged...
Other than that you can measure it up and find out if it's working OK... http://www.electrosport.com/technica...ding-guide.php
Old Sep 3, 2009 | 02:36 PM
thetophatflash's Avatar
I have also heard the "pop" and then no charge. New ones are finned.
Old Sep 3, 2009 | 03:16 PM
Letsrideinsc
thank you!!! guess what I'm doing when i get home tonight? Drinking beer, that's what.
Rdm1776
Jul 22, 2013 12:26 PM
AKBadRep
May 31, 2011 11:14 AM
offroad_rider2008
May 16, 2011 11:37 AM
viperkillertt
Aug 28, 2009 07:13 PM
ClevelandSuperhawkRumble
Mar 13, 2005 03:09 PM
