Seized Oil Filter
Old 07-12-2012, 04:53 PM
TJ91's Avatar
TJ91 is on a distinguished road
Seized Oil Filter
Hey guys, hope I'm not posting this in the wrong section. Im currently trying to do an oil change on the bike and the filter seems to be seized, I broke two oil filter strap tools already.
Any usefull tips on getting it out?
I'm about to put the old oil back in and ride over to the bike dealer tomorrow and have them do it but I really want to get this damn filter out and just finish the oil change.
Hopefully I can get some help on here
Thanks!
TJ91 is offline
Old 07-12-2012, 05:08 PM
Former Superchicken Owner
RWhisen's Avatar
It's a screw on filter and shouldn't be that difficult. As a last resort I have driven a screwdriver through the body of the filter near the base and use it as a wrench on some cars.
RWhisen is offline
Old 07-12-2012, 05:13 PM
TJ91's Avatar
Yeah I've been watching videos on YouTube and people came up with some clever ways to remove it but now I'm think I should just bring it back to the powersports store and have them do it
I was contemplating the screwdriver method but then realized that if I'm unsuccessful at that point, then only way to bring it to the shop is on a flat
TJ91 is offline
Old 07-12-2012, 05:27 PM
Wicky's Avatar
Just think Buffy the Oil Filter Slayer...
From UK Firestorm Workshop day as BSM's machine of darkness is slain with the aid of a screwdriver, mallet and a clove of garlic
Have you tried one of these?
http://www.ebay.co.uk/itm/Oil-Filter...ht_2780wt_1163
Wicky is offline
Old 07-12-2012, 05:35 PM
Performance Tool Oil Filter Wrench 2.250-3.500" Diameter Range Cushioned Handles on eBay!
I've had good luck with these as well (at any auto store). You can crimp the snot out of the filter with them to get a good grip/leverage.
+1 on the screwdriver in a pinch, though
7moore7 is offline
Old 07-12-2012, 05:39 PM
TJ91's Avatar
Thanks alot guys. The oil filter slaying is hilarious lol I think that will be my "if all else fails" plan
Thanks again guys lol
TJ91 is offline
Old 07-12-2012, 06:30 PM
1971allchaos's Avatar
Buying used S-hawks, and other bikes.. The oil change is -like the first process, Even before attempts of starting the bike..
I have used a monster set of channel lock pliers...
1971allchaos is offline
Old 07-12-2012, 06:32 PM
That is what I always use when I find one that is stuck
8541Hawk is offline
Old 07-12-2012, 07:16 PM
mboe794's Avatar
I once ripped the shell off a filter using the screwdriver method on a friend's bike. Wasn't too bad of a deal actually. Once that was off I found a good spot to put a wrench on it.
mboe794 is offline
Old 07-12-2012, 07:22 PM
twinman's Avatar
twinman is on a distinguished road
u took the words right out of my mouth vtr surfer LOL!!!!
twinman is offline
Old 07-12-2012, 08:12 PM
Hey VTR surfer... May I add to your suggestion, of buying a "socket style" oil filter wrench...
I would only suggest taking oil filters off with this tool... ONE hand tight is more than enough tighting pressure on a oil filter, ON any engine... after you lube the O-ring.
Just IMHO...
Old 07-12-2012, 08:54 PM
superdutyd's Avatar
Try tightening it more first then loosen it. It works most of the time. I have metal filter wrenches to loosen them with a hole drilled in the side. If i get a real stubborn one i screw the wrench to the filter.
superdutyd is offline
Old 07-12-2012, 09:45 PM
autoteach's Avatar
If you ever worked on a BMW K bike, then you may just know what a stuck filter is really like. Seriously.
autoteach is offline
Old 07-12-2012, 09:53 PM
DONT admit defeat and slink back to the stealership. I have used the screwdriver method @ a zillion times. Also the channel lock pliers thing works too. You can crush the filter slightly to create 2 flat surfaces as you turn.
Fear not, it will come off.
smokinjoe73 is offline
Old 07-12-2012, 10:16 PM
New Hawk Rider
eersfanpilot's Avatar
eersfanpilot is on a distinguished road
Ran into the same issue when I tried to change mine. I took a drill, drilled all the way through it, inserted a long screw driver and used it as a handle. Worked like a charm!
eersfanpilot is offline
Old 07-12-2012, 10:52 PM
TJ91's Avatar
Wow guys! First off I want to thank you for all the help. This is my second forum, I'm currently on a great Camaro forum and I was hoping this forum would be a great community and it truly is! So thanks again
As for the filter, I will not accept defeat lol. I will get that filter out as soon as I get home from work one way or another. Think I'm going to try the channel locks, if not, screwdriver method looks like the way to go!
And yeah it was Honda who did the oil change last and clearly over torqued everything including the drain plug!!! I'll be torquing everything to spec
TJ91 is offline
Old 07-12-2012, 11:35 PM
geezer
oahu hawk's Avatar
I like to loosen up my bike/car oil filters with the engine cold, then snug the filter up enough so it doesn't leak and then run the engine to bring the oil up to temp for draining...never had a stuck fiter using this method.
oahu hawk is offline
uchi
10-31-2010 10:18 AM
Chester3000
08-15-2009 01:26 AM
Playboysk8er5
04-15-2009 07:52 AM
roisman
04-01-2007 02:08 PM
Speed_Demon
03-14-2006 10:18 PM
Quick Reply: Seized Oil Filter
