Ran out of fuel, long downhill
Old Oct 20, 2013 | 01:38 AM
jerryh's Avatar
Luckily rolled 3/4 of a mile and up to the pump. It only took 3.8** gallons and I'm thinking with the petcock at the rear of the tank, it starved from the looong downhill and didn't actually run empty. I'ved noticed the gauge changes going up and downhill as well. If your trying to stretch a tank and climbing in elevation you could get fooled by the gauge and get caught empty
Old Oct 20, 2013 | 07:00 AM
comedo's Avatar
I can lose a bar on the gas gauge going downhill and regain it on the next uphill. Changing the ride height also has an effect on how far you can go before the first bar disappears.
Old Oct 20, 2013 | 07:20 AM
Not like anyone NEEDS a reason to wheelie on a long downhill, but there you go.
Old Oct 20, 2013 | 08:46 AM
red02vtr's Avatar
red02vtr is on a distinguished road
After running out of fuel a few times, I just try and fill before 120 miles. Usually takes 2.9 - 3.2 gal. Haven't got the ***** to test that shrimpy gas tank on a consistent basis. If you got 3.8, awesome.
Doesn't the tank shape prevent it from emptying the whole 4.2 gal?
Old Oct 20, 2013 | 09:39 AM
Same reason to do Endos on long uphills... I thought everyone knew this?
Old Oct 20, 2013 | 09:43 AM
JamieDaugherty's Avatar
I've put 4.1+ gallons into my tank several times. Without running out of gas, mind you. If everything is good working order you should get every drop from it.
I'm thinking it would need to be one heck of a downhill slope to slosh 0.5 gallons to the front of the tank - like a 50% grade. I'm wondering if you ran out for a different reason?
Old Oct 20, 2013 | 11:53 AM
jerryh's Avatar
Its probably a good mile and a half slope. Wonder if a petcock diaghram that's going bad could do it. Lately, every once in a while it has been flaming out while decelerating and at idle. With the flame out it dies instantly. Going downhill it sputtered, tried sloshing fuel around barely made a difference. I think you guys are right and will try wheelying downhill and endo's up. That should fix it.
Old Oct 20, 2013 | 01:43 PM
insulinboy's Avatar
reason number 357 I always make sure to fill up around 100 miles. I'm another that doesn't like to stretch the tank. Makes me miss my 600 that I could get 250 miles out of a tank though
Old Oct 20, 2013 | 03:34 PM
996thehawk's Avatar
996thehawk is on a distinguished road
I ran out last week week at around 105 miles. I was riding with my wife though. Did anyone have an issue with it running rough after putting gas back in? My bike wouldn't idle and seemed as if it was only running on cylinder for a while. When I started to ride, as soon as I hit 2nd gear is cleared up and has been fine since? Is this normal? MAybe the carbs just had to fill back up?
Old Oct 20, 2013 | 03:55 PM
^ If you overfill it, sometimes it creates a vacuum lock (where it can't breath and so the air can't expand, making it hard for the fuel to drain to the carbs). If it happens again, try popping the fuel cap with a spare key or before you ride off and it should fix it. And don't fill it all the way to the brim
Old Oct 20, 2013 | 07:44 PM
jerryh's Avatar
I have know idea if this is even possible but the occational flame outs seem to coincide with a few flaky leds going out on one of the 12" strips. I'll make sure to check next time.
Old Oct 20, 2013 | 08:42 PM
996 I am sure there is a Groucho Marx joke about you wife in there somewhere.
I never get that many miles unless I am out on the open road. In the city, way fewer miles, like maybe 80 before I fill up. (with or without my wife)
Old Oct 21, 2013 | 10:42 AM
ahernandez74's Avatar
ahernandez74 is on a distinguished road
Lucky you. Personally I don't like to run it that close to empty... I'll actually try to fill up before its at a quarter tank left.
Old Oct 21, 2013 | 02:35 PM
996thehawk's Avatar
When I ran out, I only put about 2 gallons back in. That's when it ran rough. Like I said it cleared up in 2nd gear. I was just curious if it was normal for it to do that after running out. Thanks though, I'll keep that in mind when filling up. I tend to top it off to the very top because of its poor gas mileage.
Old Oct 21, 2013 | 02:45 PM
Some people don't have a problem topping it off for whatever reason (yours truly), but if vacuum lock is indeed the culprit, then it is a very easy solution. Maybe just bad gas in the hose at the station or something...
Old Oct 21, 2013 | 02:49 PM
jerryh's Avatar
Kink in the overflow tube?
Old Oct 21, 2013 | 02:51 PM
jerryh's Avatar
I've been doing a lot of miles so I try to stretch it
Old Nov 16, 2013 | 07:22 AM
RoadManiac's Avatar
European Member
not going to be having this issue at all
my country is flat as hell, highest "mountain" we have here is 300 meters high
with like a 0.5% incline
Old Nov 16, 2013 | 08:20 AM
In that case, you may wheelie everywhere or do endos all over the place or mix it up. Your call.
Fox
Dec 14, 2010 11:46 AM
havoc7685
Sep 16, 2010 01:13 PM
CentralCoaster
Sep 17, 2008 03:41 PM
denmah
May 4, 2006 01:38 PM
Philipian Ricer
Apr 11, 2005 10:33 PM
