Ran out of fuel, long downhill
Luckily rolled 3/4 of a mile and up to the pump. It only took 3.8** gallons and I'm thinking with the petcock at the rear of the tank, it starved from the looong downhill and didn't actually run empty. I'ved noticed the gauge changes going up and downhill as well. If your trying to stretch a tank and climbing in elevation you could get fooled by the gauge and get caught empty
I can lose a bar on the gas gauge going downhill and regain it on the next uphill. Changing the ride height also has an effect on how far you can go before the first bar disappears.
Not like anyone NEEDS a reason to wheelie on a long downhill, but there you go.
After running out of fuel a few times, I just try and fill before 120 miles. Usually takes 2.9 - 3.2 gal. Haven't got the balls to test that shrimpy gas tank on a consistent basis. If you got 3.8, awesome. :cool:
Doesn't the tank shape prevent it from emptying the whole 4.2 gal? |
Originally Posted by VTR1000F
(Post 364207)
Originally Posted by red02vtr
(Post 364210)
Doesn't the tank shape prevent it from emptying the whole 4.2 gal? I've put 4.1+ gallons into my tank several times. Without running out of gas, mind you. If everything is good working order you should get every drop from it. I'm thinking it would need to be one heck of a downhill slope to slosh 0.5 gallons to the front of the tank - like a 50% grade. I'm wondering if you ran out for a different reason? |
(Post 364215)
reason number 357 I always make sure to fill up around 100 miles. I'm another that doesn't like to stretch the tank. Makes me miss my 600 that I could get 250 miles out of a tank though
I ran out last week week at around 105 miles. I was riding with my wife though. Did anyone have an issue with it running rough after putting gas back in? My bike wouldn't idle and seemed as if it was only running on cylinder for a while. When I started to ride, as soon as I hit 2nd gear is cleared up and has been fine since? Is this normal? MAybe the carbs just had to fill back up?
^ If you overfill it, sometimes it creates a vacuum lock (where it can't breath and so the air can't expand, making it hard for the fuel to drain to the carbs). If it happens again, try popping the fuel cap with a spare key or before you ride off and it should fix it. And don't fill it all the way to the brim ;)
I have know idea if this is even possible but the occational flame outs seem to coincide with a few flaky leds going out on one of the 12" strips. I'll make sure to check next time.
996 I am sure there is a Groucho Marx joke about you wife in there somewhere.
I never get that many miles unless I am out on the open road. In the city, way fewer miles, like maybe 80 before I fill up. (with or without my wife) |
Lucky you. Personally I don't like to run it that close to empty... I'll actually try to fill up before its at a quarter tank left.
Originally Posted by 7moore7
(Post 364235)
Originally Posted by 996thehawk
(Post 364291)
When I ran out, I only put about 2 gallons back in. That's when it ran rough. Like I said it cleared up in 2nd gear. I was just curious if it was normal for it to do that after running out. Thanks though, I'll keep that in mind when filling up. I tend to top it off to the very top because of its poor gas mileage.
(Post 364294)
Some people don't have a problem topping it off for whatever reason (yours truly), but if vacuum lock is indeed the culprit, then it is a very easy solution. Maybe just bad gas in the hose at the station or something...
Originally Posted by ahernandez74
(Post 364271)
not going to be having this issue at all
my country is flat as hell, highest "mountain" we have here is 300 meters high with like a 0.5% incline :rolleyes: |
In that case, you may wheelie everywhere or do endos all over the place or mix it up. Your call.
