New member - Fairing question
Old May 10, 2012 | 11:30 AM
leonis75's Avatar
leonis75 is on a distinguished road
Hello All,
I'm a new (brand new) rider This is my first bike.
I just bought a 2004 super hawk Its in very good condition 13000 miles a few nicks and scratches.
I have 1 question. there is a crack on the right side fairing.Its at the bottom of the radiator opening and it runs across. Its about a inch long. Can this repaired inexpensively?
Old May 10, 2012 | 12:17 PM
aja's Avatar
aja
A fiberglass repair kit will take care of it, but it may need repainting if you want it flawless.
Being a new rider and jumping right onto a liter bike, take it easy. This may not be the fastest liter bike, but its more than enough to catch you off gaurd. If you get used to the hawk and jump on something else, remember the hawk is very forgiving while other bikes aren't.
Most people are against a liter bike for new riders, but I don't think the hawk is too much, as long as you ride smart and safe.
Old May 10, 2012 | 12:19 PM
GTS's Avatar
GTS
Seasoned tech
Welcome and congrats on being a new rider. That's a lot of bike for a begining rider!
The fairings on these things, or most any bike for that matter, aren't cheap! You may be able to fiberglass or epoxy the inside of it to hold it there and keep it from progressing but to actually repair you're looking at paint, which isn't cheap, or a new fairing, which isn't cheap either.
Old May 10, 2012 | 12:37 PM
leonis75's Avatar
Thanks for the advice!
Ive been taking it slow and easy. I took the riders course a couple of years ago and I'm taking it again in a few weeks.
I was thinking about going smaller but the price was right and im a big guy (6ft4 275lbs)
For the painting, Would you go to auto body shop?
Old May 10, 2012 | 12:46 PM
You can use this product PLASTEX PLASTIC REPAIR KITS and fix it from the inside with good results or you can plastic weld it back together (there are various methods to do this from a true plastic welder set up to a soldering iron) but nether way would require you to repaint the part and both will bond the ABS better than most epoxies or fiberglass types of repairs.
Old May 10, 2012 | 01:08 PM
blamecanada's Avatar
blamecanada is on a distinguished road
I learned on my hawk as well...(I had another bike for a week or two first though) had some dicey moments (tank slappers and sliding rear wheel) while learning to go fast in the canyons...I think as long as you respect it each and every time you climb on you should be ok.
stay off the gas and keep the revs down till you're more confident...I think the first month I had the bike I got 41mpg all the time because I rode it so conservatively
Old May 10, 2012 | 01:58 PM
aja's Avatar
aja
You'll appreciate the torque the hawk has, being a heavier rider.
As far as paint, if you have the skills or bravery to attempt it yourself, go for it. A body shop can be pricey. Another alternative is a product called plastidip, its a latex coating that you apply from air gun or rattle can, lasts up to a year, and when you are bored of it it perks off like a sticker with no adhesive.
Old May 10, 2012 | 03:38 PM
You have to compare the costs/time of repair and paint vs. just buying a new or a nice used fairing (if and when you can find one) and also how much of the work you'll be doing yourself. I don't consider myself an expert but I use fiberglass to repair fiberglass, not to repair plastic. A correct repair would be either to plastic weld it, or there are certain epoxies (I forget the name of a 2 part one from permatex that I've used and it works on plastic fairings like a champ) for plastic as well. I rebuilt a downed superhawk a couple years ago and did the bodywork myself, then had a bodyshop match the color and they painted the both side fairings and the tail for @$250 if I remember correctly-basically the cost of one new side fairing from ronayers. Probably a 98% color match ('99 pearl yellow is tough and I'm pretty ****) to the remaining mint bodywork I pieced together off ebay along with the stock graphics and the bike basically looked brand new. If you're really ambitious colorrite sells factory paint in spray cans (it's expensive) but I remember it ended up being more expensive than having the body shop do it for me.
benny6169
Mar 7, 2010 05:16 PM
synaptik
Apr 12, 2008 07:48 PM
1cbr_guy
Aug 28, 2007 11:30 AM
GrayHawk
May 16, 2007 09:41 AM
gsman
Mar 16, 2007 07:29 PM
