My horrid battery, and advice?
Old Mar 2, 2014 | 10:27 AM
bammerburn's Avatar
bammerburn is on a distinguished road
Hi all,
Recently I tried to take out my battery to put it on a tender (new owner here). Taking off the seat and unlatching the battery box's cover, I discover that the battery is un-removable. A fuse box (?) is in the way, so I cannot pull the battery out. Seems to be too big. After 25 minutes of struggling to pull out the battery, I just gave up.
What do you suggest I do - is there a trick to removing the Superhawk's battery? And, is there a better battery that I should grab and install as a replacement?
Old Mar 2, 2014 | 10:38 AM
VTRDarren's Avatar
VTRDarren
Pics might help here.
Old Mar 2, 2014 | 10:55 AM
If the battery is to big, the fuse holder can be pulled out of the way. Use a flashlight to see how it connects to the plastic undertray. Once the fuse holder is out of the way, you shouldn't have any problems.
If it's still stuck, use a hair dryer to warm up the plastic around the battery. It makes it a little more pliable (CAUTION: warm it. Do not put the hair dryer on the battery for an hour. Bad things can happen)
Old Mar 2, 2014 | 11:56 AM
Wicky's Avatar
Unclip the fuseholder from the plastic undertray. Once you've got a free path it should just pull out. If you still struggle thread some cable ties through both terminals and give it a tug.
Old Mar 2, 2014 | 02:12 PM
sjscicluna's Avatar
ill post a photo up i had the same issue used a bit of plastic to make a handle on the battery but screwing it into the terminals and used that to yank it out
Vegiepower
Aug 11, 2015 12:39 PM
E.Marquez
Apr 13, 2014 08:10 AM
Twitch78
Mar 14, 2013 01:33 PM
doctermac
Sep 25, 2008 10:36 AM
seattletwin
Apr 29, 2008 09:26 PM
