Battery started smoking and whistling
Old Apr 9, 2008 | 09:41 PM
seattletwin's Avatar
seattletwin is on a distinguished road
Question Battery started smoking and whistling
I attended my first track day today and wow, how fun is that! That is a different post though. After my last session I got back to the pits and heard a very high pitch whistle, combined with the sulfur smell of dying battery. I pulled the seat off and the battery was steaming and whistling like crazy. I was able to get the battery out of the bike and get it away from everyone until it cooled down.
A little history on this battery. Its over 2 years old and is a regular maintenance free OEM battery. I use a trickle charger on it since my commute is quite short. Over the winter I noticed it would not hold its charge very well especially when cold. I figured it was time to replace it anyway.
When I prepped for my track day I just unplugged all the lights and blinkers to disable them per track rules. I didn't want to just cover them with tape, for fear of cooking the tape onto the lenses and also I wanted to remove as much stuff as possible in case I crashed.
So I am thinking the battery was just worn out and died? Or maybe unplugging all the lights caused a problem? Or maybe the regulator/rectifier is bad? I have to buy a new battery before I can do any diagnostics but was wondering if anyone has any experience with this and can suggest a place to start.
And one other thing the Superhawk is a riot on the track, lots of torque, handles great and sounds wonderful.
Old Apr 9, 2008 | 10:06 PM
Little_Horse's Avatar
2nd mouse gets the cheese
I have had alot of trouble with reg rectifiers. The original one before honda made the stronger is weak to begin with so most likely by removing/ unplugging your lights it overloaded the capabilities of the regulator. Hopefully only your battery is affected. The regs are pretty easy to test. If you need to replace it though don't go aftermarket get the improved one from honda. I've also fried a battery before kinda stinky, and mine was new .
Drew
Old Apr 9, 2008 | 10:52 PM
jbaxx's Avatar
Honducati
Yeah, sounds like the battery got over-charged.
Old Apr 10, 2008 | 12:21 AM
That is exactly what happened to my battery when my R/R died. So I'd say you need a new R/R.
Be sure to either get a finned replacement, or do a mod to a R1 or GSXR unit.
Old Apr 10, 2008 | 06:16 AM
superbling's Avatar
That's how I knew my r/r had gone out. 18volts at idle! Man, my headlight sure is bright (POP!). Oops.....
Yeah, unplugging everything thus reducing the load made the symptoms more obvious.
Old Apr 10, 2008 | 07:11 PM
Those will work? That is good to know
Old Apr 10, 2008 | 08:14 PM
They not only work they are a shitload better than the stocker avail from Honda. And a shitload cheaper! Lots of posts in the archive about how to wire them up. Good luck!
Old Apr 10, 2008 | 09:24 PM
happytrack44's Avatar
WERA #44
I have a GS500E one on mine, Huge with big fins. Cheap too!
Old Apr 11, 2008 | 02:01 AM
Your battery is being over-charged... Either because it has a dead cell or your charging system is pumping waaay to much juice, possible R/R.
Old Apr 11, 2008 | 11:05 PM
vtrider's Avatar
roll through
vtrider is on a distinguished road
yeah I got a shitty aftermarket electrosport one that was charging my batt at 19 volts. My PU rep gave me a free battery though,which was cool of him
Old Apr 29, 2008 | 09:26 PM
Did some testing and the R/R was bad it was feeding out 18+ volts at 5k, I picked up a the new version (mine was the stock 98) and now all is good. New Battery $90 and $160 for R/R. All better now. Now I wonder if the R/R killed the battery or the battery killed the R/R, or maybe they both just died of natural causes. The battery was 2 years old and the R/R was stock.
Thanks for everyones advice!
Slicknick4209
Jun 14, 2012 11:28 AM
mortbike
Jun 16, 2011 04:41 PM
StoneJrW
Mar 4, 2007 11:41 AM
paintnflames
Aug 19, 2006 08:14 AM
EngineNoO9
Jun 19, 2006 09:34 AM
