Dyno results..
Old Jan 25, 2008 | 01:01 PM
mikecronis's Avatar
mikecronis
Dyno results..
This seems low.. but.. I know there's DynoJet vs. WinDyn (which they used). They said they corrected for altitude. It's a stock bike with a K&N, re-jetted for altitude (smaller jets).
Opinions? (Oh, and they spelled my name wrong.. CronAS.. nice.) ;(
Old Jan 25, 2008 | 02:03 PM
drew_c14's Avatar
Seems a little low, but I've seen it before too. Why smaller jets? I know about the altitude thing(I grew up in Aurora) but the bikes are kind of lean stock, then add in the K&N and you might be WAY lean.
Old Jan 25, 2008 | 08:11 PM
mikecronis's Avatar
mikecronis
Bike was running rich even -after- the jets. Honda service manual recommends 1 size down above 4000 ft. altitude. After I did so, bike was VERY MUCH more snappy and accurate. Still not getting enough air though, plugs were dark (but not overly so). I ride a lot in the mountains near Mt.Evans and what-not so I'm usually at altitudes around 10-12,000 feet. I tried that altitude with stock jets and couldn't even get the bike to start for quite some time, now it's a breeze.
Dyno was done at 6000ft. Supposedly altitude was adjusted-for. Dynojet says the Hp was 93.0, STP says 87.9 DynoJet dyno, altitude-corrected. I was told that resistance was set to "normal" (so just a bit) but was told a lot of people that dyno bikes set it to a negative rating, giving inflated results. By adjusting this, it gives the customer happy smiles, or so he says, but it's bogus.
I'm still getting around 46mpg.
Suggestions?
Old Jan 26, 2008 | 06:01 AM
drew_c14's Avatar
The question is are you unhappy with the way the bike rides and feels? If not, then who cares what the dyno says. If you still have stock gearing try adding a couple teeth to the rear sprocket. That makes a big difference in the feel and response.
Old Jan 26, 2008 | 08:10 AM
mikecronis's Avatar
mikecronis
Ah, well I'm down a tooth in the front. The bikes feels snappy but, being a technical sort, I just was wondering if these values are poor and therefore something's wrong or not.
Old Jan 26, 2008 | 08:22 AM
Two points:
1) torque curve is really nice and flat
2) output decreases approx 3% per 1000 ft, so your numbers at sea level would be almost 20% higher
Old Jan 26, 2008 | 09:07 AM
mikecronis's Avatar
mikecronis
Supposedly they compensated for altitude, though.. that's where I'm concerned. If they didn't, then I'm better than good, losing only about 13%, if they DID compensate, then I am losing 13% for no good reason.
They gave me another chart that indicates SAEPwr vs. STPPwr vs. DJWhPw. I think it's a rating of two dynometers. I believe the first one is Hp of 84.5, the second is the corrected version that reads 87.9 and then the final one, 93 Hp is what DynoJet would read.
Old Jan 26, 2008 | 10:17 AM
I don't agree with you on this. With HRC needles and stock jets I'm right at 14:1. The pilots are a touch lean, but the stock mains are fine unless you do engine mods or try an aftermarket filter.
Old Jan 26, 2008 | 01:30 PM
Jim TT's Avatar
Jim TT
I may be the Dyno; look at this Factory Pro dyno run:
Old Jan 26, 2008 | 04:30 PM
Drew,
I dunno about yours, but mine was rich stock at sea level. After the bafflectomy and shimming needles it was closer to optimum. Then I went to K&N and slip-on and was a new story from there.
Old Jan 26, 2008 | 06:04 PM
seems low
aprox w/ jet kit (jets unknown) & 2bros per ur chart
peak hp 94 @ 8700
" tq 62 @ 7000
hp = tq @ 5200
seem a bit low 100+ & 67+ possible
eh Greg?
Old Jan 26, 2008 | 06:31 PM
LotusLand's Avatar
Old Guy
LotusLand is on a distinguished road
Just what is it that they do when they "adjust for altitude"? The bike can be adjusted for altitude as you have done, but a dyno? Do dyno's work different at 6K feet?
Old Jan 27, 2008 | 09:20 AM
Jim TT's Avatar
Jim TT
Greg, all readings I have seen on the Factory Pro dyno are low, that is my point, dynos read differently and a base line run vs runs with mods is what matters not the reading itself. Are you making more power with the change you are testing is the only relavent question.
BTW the jets on the above run are Factory Pro.
Lotusland, there is a mathematical correction formula for altitude, barometric pressure and temperature. JIM
Old Jan 27, 2008 | 01:07 PM
mikecronis's Avatar
mikecronis
Generally, Hp & torque should be about 3% loss per 1000 feet of altitude. At over 4000ft altitude, since the bikes are carburated, they should be rejetted (see "Zen and the Art of Motorcycle Maintenance") leaner (ie. smaller jets). At 6000 ft. (Denver) you automatically lose 18% off the bat. Altitude adjustment just adds the 18% back on for customer approval and grins but it's BS. It's just a, "This is what you'd get a sea-level" with perfect barometer readings number by multiplying (in this case) the 18% you lost on top of the actual number.
I've known a few non-jetted Colorado Shawks only getting 35 mpg or less, sometimes in the high 20s. I'm getting 41-46mpg and once over 50mpg on a long, slow boring prairie ride. My low-fuel light comes on at 146 miles or later. My speedo has be re-calibrated to GPS spot-on using a Garmin StreetPilot C340 and an installed Speedohealer (which I recommend).
I guess I'm about where I should be on Hp, so I'm pretty happy. Vibrations mysteriously "went away". They re-adjusted the carbs using the pressure guage as opposed to eyeballed 2 1/2 turns out BS and hmmmmm... what do you know? Still, they said it was already spot-on before they checked it. I doubt it.
Old Jan 29, 2008 | 07:44 PM
Your speedo healer is throwing off your odometer, which just happens to be right on the mark. The speedo is off about 7-8% optimistic from the factory. So this is going to throw off your MPG calculations as well. If I'm thinking correctly, this will actually give you better mileage than what you think you're getting.
Old Jan 29, 2008 | 08:07 PM
mikecronis's Avatar
mikecronis
Agreed, and good point but I already calculated for that.
Old Jan 29, 2008 | 08:10 PM
I thought the speedo reads off the countershaft sprocket and is set for the OEM 16/41 sprocket combo and OEM Dunolp D204s (were D204s the oem rubber, its been so long)? If you go up 2 teeth in the rear you will read 4%faster on the speedo, or approximately 12~13% faster than actual. The diameter of whatever the tires are + or - the OEM Dunlops will also be a factor (excluding wear). Correct?
Old Jan 29, 2008 | 09:29 PM
Yeah, but I didn't check your math. Point is, if stock the speedo reads high and the odo is spot on, no matter what you change the gearing to, if you use the healer/black box to calibrate the speed correctly then the odo will be "slow".
RymerC
Sep 20, 2008 12:53 PM
AZZKIKER
Feb 9, 2007 04:38 AM
killer5280
Feb 1, 2006 05:13 PM
SoCalVTR
Jun 15, 2005 10:50 AM
NZred
Jul 29, 2004 12:59 AM
