Today's Dyno Results
Old Jan 30, 2006 | 04:12 PM
killer5280's Avatar
Since I'm planning to install high compression pistons and have some valve, cam and port work done to my Superhawk I wanted to get a baseline dyno run to compare where I am now with what I end up with.
My Hawk is a 1998 model with about 16,000 miles. It has D&D slipons, a stock air filter, shimmed needles and +1 size on the main jets. Otherwise everything is stock.
I don't have the graphs from the dyno run yet, but I will post them here when I get them, which should be in the next day or two.
The best run was just over 104 HP with 66.5 lb. ft. of torque. The graph is smooth with a dip around 4000 rpm indicating that the engine would probably benefit from changing the pilot jets to 48s. This confirms my seat of the pants impression of a slight flat spot or hesitation low in the rev range. Not bad, but not perfect. Top end jetting looks just about right.
Old Jan 30, 2006 | 04:19 PM
jschmidt's Avatar
jschmidt
I'd call that a slow needle. Anyway, congrats on the run.
Old Jan 30, 2006 | 06:08 PM
killer5280's Avatar
Re: Today's Dyno Results
Could be. It does seem a little high to be the pilots.
Old Feb 1, 2006 | 04:22 AM
woodman's Avatar
woodman
I thought slow and pilot were different names for the same jet.
Old Feb 1, 2006 | 06:33 AM
jschmidt's Avatar
jschmidt
Slow Jet is another name for Pilot Jet. I mean the needle is rising too slowly. It could be set too low or it could have a taper that is too blunt.
Old Feb 1, 2006 | 09:13 AM
killer5280's Avatar
Well, the needle is the stocker shimmed a little. The mechanic at my shop says he has done jet kits on several VTRs and always changes the pilots to 48's, but I bet at the same time he installs the Factory needles as well. It probably is the needle taper.
Old Feb 1, 2006 | 12:46 PM
killer5280's Avatar
Here is the dyno graph. The dip is pretty ugly.
Old Feb 1, 2006 | 01:09 PM
Loco's Avatar
Loco
Yeah, thats a big flat spot.
Old Feb 1, 2006 | 04:12 PM
jschmidt's Avatar
jschmidt
Stick another washer under it. The dip is right in the middle of the needle circuit range.
Old Feb 1, 2006 | 05:13 PM
killer5280's Avatar
I'll give it a shot.
RymerC
Sep 20, 2008 12:53 PM
mikecronis
Jan 29, 2008 09:29 PM
AZZKIKER
Feb 9, 2007 04:38 AM
SoCalVTR
Jun 15, 2005 10:50 AM
NZred
Jul 29, 2004 12:59 AM
