Dont Choke her TOO LONG ! ! !
Old 03-26-2005, 12:10 AM
ClevelandSuperhawkRumble's Avatar
hey guys... just curious.. with all my old bikes and my cbr, i pull out the choke when i first start it... wait until the RPMs start floating up higher (about 30 seconds on my IL4 cbr ) , then push it in and let it puff puff until shes warm. well, is this the same procedure for 90 deg. twins? particularily my new superhawk? just curious if you could just give me some input on what you guys like to do when warming up bike properly without chokin too long and causin unwanted heat or whatever. thanks :P
ClevelandSuperhawkRumble is offline
Old 03-26-2005, 04:02 AM
AZZKIKER's Avatar
Re: Dont Choke her TOO LONG ! ! !
Depending on the outdoor's temp, yes that's what I do. Usually I use it for like 30 sec max.
AZZKIKER is offline
Old 03-26-2005, 08:33 AM
Jason C's Avatar
Jason C
Same here...no more than 30 seconds, tops.
Jason C is offline
Old 03-27-2005, 08:06 AM
Hawknut's Avatar
Hawknut
No more than necessary to keep it running. Even with Yosh cans and no carb mods on mine it never takes full choke to start. When it's cold you can tell when you don't have enough choke on and blip the throttle. It'll pop back thru the carbs hard enough to feel thru the tank and seat.
Hawknut is offline
Old 03-27-2005, 06:19 PM
99Hawk's Avatar
99Hawk
Originally Posted by ericsuperhawk";p=&quot
Mine has to be ridden pretty hard to get mich of a rise out of the gauge. Either the bike has an extraordinary cooling system or my temp. sensor doesn't work so well.
My guage hardly moves if it's cool out (less than 60°), between 60 and 70 it will come up slowly, over about 75 the guage seems to come right up into mid range quickly and pretty much stay there unles I get stuck at stop lights. I've considered blocking off some rad when I'm out in temps less than 60° .
99Hawk is offline
Old 03-29-2005, 03:13 PM
vitter's Avatar
vitter is an unknown quantity at this point
I started my bike today, and it would not start with the choke.
so I tried it without the choke and it started fine(13C).
My old GSXR needed the choke in any temps, except 25C+.
vitter is offline
Old 03-29-2005, 04:34 PM
faz
faz's Avatar
faz
I was doing it all wrong. I was setting the choke on, keep it on for about 1 minute and then start to ride, and about 1 mile of riding I would turn it off. I have had a couple of cases that this caused rich mixture, which probably caused fouling the plugs, which probably was the cause of bad performance I experienced a couple of times.
Now I only use the choke to startup, and turn it off after about 30 seconds before I start to ride.
faz is offline
Old 03-29-2005, 05:44 PM
jschmidt's Avatar
jschmidt
Its right that you should turn it off as soon as your bike starts to warm up. But it typically takes 1-2 minutes to do so, unless it is really warm. Two minutes won't foul your plugs. Forgetting to turn it off is what fouls plugs.
jschmidt is offline
nath981
01-14-2011 05:20 PM
havoc7685
09-16-2010 01:13 PM
ranchomice
04-10-2010 12:08 AM
Otto Man
06-28-2007 08:16 AM
EngineNoO9
02-20-2007 08:24 PM
Quick Reply: Dont Choke her TOO LONG ! ! !
