carb sync mods
Old Mar 29, 2005 | 03:15 PM
99Hawk's Avatar
99Hawk
Re: carb sync mods
Since there is no 'flow' through the 'T'd off connection (it is just a static vacuum) it doesn't make any difference in the actual reading to have it 'T'd off or not.
I suppose there are many ways to run the lines and my approach was to make the lines easily accessable but keep them hidden. These shots below may give you another idea before you run your plumbing.
Here is the view you'd see just looking right at the 'stealth' line location
This closer shot shows the two lines capped off and tied back
Both lines are just long enough to get a hold of to hook up the guages.
Here the caps are off and you can see that I took a 1 inch piece of steel brake line and inserted it into the lines. The caps then fit perfectly. My red marker is simply marking the 'rear cyl' line.
By the way, for some reason I had problems using a standard plastic auto 'T' connection at the fuel valve. It would sometimes break if I lifed the tank back. So I got pissed enough to take two pieces of steel brake line and braze them into a 'T' (after drilling a small hole) and now the 'T' connection not being plastic seems to have no problem holding up to abuse.
Old Mar 29, 2005 | 05:47 PM
jschmidt's Avatar
jschmidt
No it won't make any difference. The reason you start and clamp is so that vacuum will be pulled/maintained on the tank valve so that gas will flow during the procedure.
Old Mar 29, 2005 | 08:16 PM
99Hawk's Avatar
99Hawk
Re: carb sync mods
The caps were from an autoparts store, they normally sell in a card display, just ask the parts dude.
No, it doesn't matter where the T is placed, mine is probably 2 inches from the fuel valve.
Dave Wicks
Jun 21, 2008 06:56 AM
reaper
Sep 22, 2007 10:15 AM
VTRFISH
Aug 16, 2005 10:57 AM
mikecronis
May 26, 2005 08:10 PM
cozart02
Apr 14, 2005 06:31 PM
