Yamaha Carb Cleaner Trick - Questions
Old Aug 9, 2010 | 01:02 PM
mchawkmaster's Avatar
mchawkmaster is on a distinguished road
A couple quick questions as I will be performing this "trick" soon:
1. Can you put too much of the cleaner in the carbs and it go into the engine and eat something important?
2. If some stays up in the gas lines will it melt them?
3. If 1 and 2 can happen, how do you know when you have put enough in there?
4. When adding the cleaner to the bike should it be on a rear stand or kickstand (my only two options) or does it matter?
May be beatin a dead horse but I really don't wanna screw my bike up
Old Aug 9, 2010 | 04:45 PM
motojoe's Avatar
Sexual Daredevil
If you drain the float bowls all the way and use the gas line to put the cleaner in you should have no problem. In theory, the float needle will cut off the flow when the bowl is full of the cleaner. No, the cleaner is not supposed to damage rubber or o-rings, so your fuel line should be safe. Use the stand. Take it off the stand when shaking(as others have suggested).
Old Aug 9, 2010 | 08:23 PM
Thanks for the input motojoe.
I see you are from charlotte NC. I grew up in liberty NC about a straight shot up highway 49 north for about an hour
Old Aug 9, 2010 | 08:26 PM
It's a lot more fun to pull the carbs to clean them.
Old Aug 9, 2010 | 09:25 PM
autoteach's Avatar
Despite what other forum members have said, you cannot get AIDS from pulling carbs and cleaning them properly.
Old Aug 9, 2010 | 09:55 PM
No, I just get a sore back...but then I'm an old fart.
It sure does run great after the job is done though.
Old Aug 10, 2010 | 09:04 AM
motojoe's Avatar
Sexual Daredevil
Been throught there a time or two, or twenty.
Old Aug 10, 2010 | 11:37 AM
Originally Posted by RK1
Took the VTR for a ride a few days ago after it was sitting for awhile. Had the idle to 3500 rpm hiccups.
Decided to try a new "trick".
Got a couple of 3 ft pieces of clear plastic tube. Snugged them up on the drain spout of each float bowl. Kind of a pita but using some long surgical foreceps got them on in a few minutes.
I hung the other ends of tubing higher than the carbs and opened the drain valves, didn't drain, just opened them.
Using a syringe I pumped about an ounce and a half of Yam Carb Cleaner up into each carb and closed the valves.
Rocked the bike a few times, pressed the kill switch to off and blipped the starter a couple of times and left it for an hour and a half.
Drained the bowls through the still attached tubes into a container, yanked off the tubing, closed the drain and fired her up. Problem solved, bike runs perfect again.
Total time actually working on it was maybe 12 or 15 minutes.
What the *bleeeep* do you guys have in your fuel anyways?!
My bike can sit for three months without anything done to it and I just punch the button and ride it... Done that every year for winter storage...
Yeah, it will cough and sputter until the gas sitting in the carbs have gone though, but that's it...
So far I haven't needed to clean my carbs more than once, and that was my own fault to boot...
Old Aug 10, 2010 | 01:16 PM
Well... All our gas have been 10% or more corn liquor for the last 15 years around here, so that's not it... It eats older hoses and membranes, but it doesn't change the shelf life noticably....
Yeah... I probably could make do as well if I got it at those prices... But then my bike would still never need cleaning, since I'd ride it around the clock...
Old Aug 10, 2010 | 07:50 PM
This sounds interesteing. Hopefully after the initial "cleaning" my hawk will be good to go for a while but just for kicks and wiggles would blipping the throttle with the carb full of cleaner foul the plugs out?
Fun times right there... If you blinked you missed it . Ever stopped at any of the famous eatin places there?
My hawk is a 1998 and it has a little over 11000 miles on it which isn't much. Hopefully the problem is over the years goo has accumulated and partially blocked the slow jet (thanks other members for that help). Won't ever have this problem again FO SHO
Thanks for the help guys.
Oh yeah... About 3 hours ago i pulled the beast apart and filled er up with carb cleaner. will drain either tomorrow evening or thursday after a lotta good shakin.
Be on the lookout for the results of the carb cleaner trick. Also planning to do PAIR removal while all is apart. How loud is the popping supposed to be when the PAIR system is left intact because right now it sounds kinda trashy?
Old Aug 11, 2010 | 07:41 AM
Randman's Avatar
Moderate-whore
I think you had better start by reading this thread first.. https://www.superhawkforum.com/forum...ad.php?t=10950
Old Aug 11, 2010 | 01:04 PM
No reason to mess with the throttle. You might blip the starter button a time or two with the kill switch/ignition circuit off to suck a bit up into the jets, a "blip" being a fraction of a second.
I saw that mistake as soon as I posted last night but didn't worry with trying to fix it. I'm going to do it this evening. Will this little bit that gets sucked into the jets drain back out or will I need to run the starter for a few revolutions to clear it out once I get everything back together?
Old Aug 11, 2010 | 01:12 PM
and make sure you read the whole thing.......
Old Aug 11, 2010 | 01:28 PM
If I ever have 9 hours of boredom, I will. I did see your many falic symbols that are hilarious! Can't figure out the OGC one though. Maybe my mind isn't dirty enough.
Aug 13, 2010 11:18 AM
5150
Jul 29, 2010 10:17 PM
joshuatest
Mar 5, 2008 05:19 PM
The Hawk Guy
Apr 18, 2007 08:44 PM
CNI Dawg
Mar 4, 2006 09:47 PM
