Wiring harness gets hot, specifically...
Old Sep 21, 2008 | 04:21 PM
Chuey's Avatar
Chuey is on a distinguished road
Hi folks, anyone have any idea why a wiring harness would get hot. More specifically the one with 3 wires I believe that are yellow. My bike recently died again on the road after replacing the R/R a year ago. Recently I found one of the three wires (I didn't manage to chase down where the wires are connected to, but there are 3 of them) melted.
So I respliced the wire with fresh wire and the bike started right up after putting the battery on the tender overnight. No matter what RPM I can't get the voltage to go above 12.6V. This can't be my RR or stator can it, I had those replaced less than 5K.
The one thing I noticed is that the three wires are getting hot.
Old Sep 21, 2008 | 04:31 PM
Gregw's Avatar
If they are plugged into the R/R, they go to the stator.
Old Sep 21, 2008 | 04:46 PM
What R/R did you use?
Old Sep 21, 2008 | 05:51 PM
Chuey's Avatar
had a shop do it, it was a finned one...
Old Sep 21, 2008 | 10:19 PM
a71goatboy's Avatar
OH CRAP!
a71goatboy is on a distinguished road
Wires get hot or melt due to shorts, but usually the fuse eats it first. Or something is trying to pull more volts than the gage of wire allows or your charging system is capable of providing. Trace they wires, but you should be charging at 13.5V or so. This could be the real issue. It could be under powering your whole electrical system.
Old Sep 22, 2008 | 03:34 AM
Hammer7205's Avatar
Hammer7205 is on a distinguished road
Look for shorts, or **** - poor connections (i.e. Corroded, loose, etc..) any kind of resistance or overloading (as stated by somone else..) will cause those wires to heat up. Good luck, electrical problems can (sometimes) be a bitch..
Old Sep 22, 2008 | 09:42 AM
Even the finned ones aren't perfect (though they are better than the original).. Do you know anyone with a similarly aged Honda? (most honda's of that time frame used the same R/R) this would let you swap temporarily to see if it is the problem again.
outrigger
Mar 9, 2013 11:02 AM
wsharpman
Jul 4, 2012 02:31 AM
johnnyhonda
Jul 26, 2010 01:53 AM
boxdogracing
Apr 26, 2010 12:13 AM
Wheelerboy
Mar 26, 2010 06:59 PM
