Will Not Start
Old Aug 12, 2011 | 06:01 PM
cyberaptor's Avatar
cyberaptor is on a distinguished road
Will Not Start
Hi Guys,
Need your expertise, my '99 Superhawk will not start. Stopped at the ATM on the way home and the bike wouldn't start. All the fuses are good, the battery is good, lights work, but when you hit the starter, nothing. Acts like there is no power. I tried to bump start it, but it wouldn't kick over.
Any ideas on what this could be?
Thank you
Old Aug 12, 2011 | 06:03 PM
thetophatflash's Avatar
Kill switch?
Old Aug 12, 2011 | 06:53 PM
wsharpman's Avatar
99 superhawk
+2 on kill switch, had that happen when prior owner was selling bike to me and he didn't check killswitch on handle lmao got bike home unloaded it and looked it over saw the switch thewn and violla it started right up.
Old Aug 12, 2011 | 06:58 PM
Was the side stand down and the bike in gear??
Old Aug 12, 2011 | 07:26 PM
shaftman_05's Avatar
shaftman_05 is on a distinguished road
The kick stand sensors are common to fail. try like posted above stand up with stand light off and bike in neutral. also check battery cable connections. mine like to loosen up on occasion and will do as you describe.
Old Aug 12, 2011 | 07:27 PM
also these bikes are harder to push start or bump than you might think...
cyberaptor's Avatar
Kill switch was in the run position (and I have since dis-assembled, cleaned, reassembled and the same result; nothing). Sidestand was up and the bike was in neutral, true neutral, the bike moved freely.
Old Aug 12, 2011 | 08:39 PM
The main fuse is located separately from all of the other fuses... did you check this one when you went through them?
Edit: NM, if the lights are on, that's not it.
What's the voltage you're reading on the battery?
Old Aug 12, 2011 | 09:37 PM
cyberaptor's Avatar
Not sure what the voltage is, have a friend coming tomorrow with a multimeter, but the headlight is still really bright and the battery is also only 6 months old.
Old Aug 12, 2011 | 10:01 PM
Once you get the multimeter you may know more, but I've seen bikes with full instrument panels and headlights working and the battery reading at 11 volts and starter did absolutely nothing.
One way to see if this is the problem without a multimeter is to jump start the bike... You can jump it from a car, just do NOT turn the car on. If this works, you will still have to diagnose the problem, but at least it gives you a direction to go.
Old Aug 12, 2011 | 10:04 PM
If you have jumper cables and a car, that is. If not that advice does you jack haha
Old Aug 13, 2011 | 10:11 AM
cyberaptor's Avatar
It's not the battery, it reads 12 volts...
Old Aug 13, 2011 | 12:05 PM
franz125's Avatar
franz125 is on a distinguished road
Check every switch,kickstand,clutch,neutral,kill and starter.
Old Aug 13, 2011 | 02:11 PM
cyberaptor's Avatar
OK, so it turns out the starter relay is bad. Quick fix I wired in a separate switch until the new relay arrives.
Old Aug 15, 2011 | 10:12 AM
tapatio's Avatar
tapatio is on a distinguished road
In case anyone else needs to do this someday (the red wires connect to the toggle switch that is mounted to the subframe in the left part of the photo; it's accessible without having to remove the seat):
As a side note, toggling the switch simply activates the starter. The key still needs to be in the ON position and the kill switch disabled for the bike to start. Obviously once the bike has started, one needs to manually toggle the switch back so that the starter is turned off.
Montana
Aug 7, 2010 07:12 PM
amhsraptor
Jul 12, 2010 06:55 PM
vtr98bob
Jul 14, 2009 08:55 AM
ghopki1
Jun 4, 2009 08:17 PM
jivtrky
May 17, 2007 12:49 AM
