WHERE DID THE OIL GO!!!!!!
Old Apr 10, 2012 | 06:37 PM
hellonwheels's Avatar
hellonwheels is on a distinguished road
I have an 03 S Hawk, miles???? no odometer whatever. Did an oil change about 1500 miles used motul 7100, no drips no smoke no nothing! check on my oil level today and was down almost bone dry! yes i feel like a hack putting my bike through that kind of extreme, didnt expect all the oil to just disappear....nearly.....where could it have gone? any help out there
Old Apr 10, 2012 | 07:08 PM
saige's Avatar
the boss
make sure you are checking the oil with the bike standing straight up,when its on the kick stand,you wont see oil in the glass.
you get accurate reading with it upright.
Old Apr 11, 2012 | 12:24 PM
checked on rear stand so thats not the issue, thanks though, i can see about a qt low, but abot 3 qts....seems suspect.... argghhh!
Old Apr 11, 2012 | 12:30 PM
If either crankcase breather comes loose then vaporized oil will vent out to atmosphere with the blowby (which is normal) that occurs. You may notice it (oil sheen on the motor or whatnot) or you may not, depending on which one comes off. Check those tubes.
Old Apr 11, 2012 | 12:49 PM
maniac2313's Avatar
maniac2313 is on a distinguished road
Thats how i found out my output shaft seal was bad when washing i thought it was chain lube then i realized it was low on oil...
Old Apr 11, 2012 | 08:57 PM
Be sure to actually drain whatever the oil is in the engine to verify it is in fact down as much as you believe before adding oil! My red 98 VTR (truly the fastest year and color) occasionally will try to freak me out by withholding oil up in the head, oil galleries, oil filter, clutch, etc rather than let the synthetic ooze (lately Shell Rotella T-6 5W-40) I use make its way back to the sump/oil sight glass. Its tricked me a few times before I got smart and drained the oil to verify what was in there. Maybe its the better than OEM back-flow valve in the Purolator One oil filters I have used for many years ((it has over 75k miles now) but it has also occurred with the W-M oil filters and Rotella dyno I use before I put it to bed for the winter and run it in with in the spring before switching back to a Purolator (though I may run the W-M filter for a few thousand just for yucks) and T6.
maniac2313
May 14, 2012 02:21 PM
5150
Jul 17, 2011 07:53 AM
AngryOlaf
May 25, 2010 09:39 AM
spladle160
Mar 15, 2010 08:42 AM
CNI Dawg
Jan 24, 2008 08:59 PM
