oil cooler line leaking at the oil pan...
Old May 14, 2012 | 11:09 AM
maniac2313's Avatar
maniac2313 is on a distinguished road
Is there any reason the clutch side oil cooler line would leak at the oil pan other than a bad fitting o ring or damage to the oil pan? Ive replaced the o ring to no avail the fitting looks ok and it appears to be holding tight and straight but when i start the bike a solid stream of oil pours out... I know theres a pressure relief valve there in the pan and dont know if that could cause this...
Old May 14, 2012 | 11:26 AM
The pressure relief valve should only open if the oil cooler is clogged somehow.
Did you get the o-ring you installed from Honda or somewhere else?
About the only thing that could make it leak would be the wrong size o-ring or one that is damaged.
Though it is possible to have some kind of crud on the sealing surface that might cause the problem if it keeps the o-ring from seating, so you might want to check that also.
Old May 14, 2012 | 12:58 PM
maniac2313's Avatar
I did not get it from honda I got it from my o ringring kit and it is the wrong size o ring it's thickness is a millimeter less than it should be... ordered one hopefully it solves the problem...
Old May 14, 2012 | 01:10 PM
I would bet that is the problem then as it is a high pressure system.
Old May 14, 2012 | 01:17 PM
GTS's Avatar
GTS
Seasoned tech
That's the problem with most of those o-ring kits is if you find the right diameter the thinkness is wrong or vice versa.
Old May 14, 2012 | 02:10 PM
maniac2313's Avatar
Yea i cant find a 11mmx3.5mm anywhere only 11x3... beat street!!
Old May 14, 2012 | 02:21 PM
saige's Avatar
the boss
yea,ive looked for o-rings for the bike,alot of it you will never find on the regular market.ive looked for a long time.its all special stuff.
best thing to do,is try to cross reference the different bikes that use the same size o-ring and go to bike shops and ask them if they have oem o-rings for those bikes.some shops have stock for other bikes with the same size parts.
i did that for the bushings on the hawk,theres alot of bikes that use the same exact part,just a different bag.
quillinsmat
Jun 8, 2014 09:41 AM
aja
May 12, 2012 02:22 AM
physician
Jun 13, 2009 11:23 AM
CyberBeast
Dec 13, 2008 03:14 PM
mikstr
Apr 25, 2007 09:00 AM
