What's that clickin noise?
Old Aug 2, 2014 | 08:13 AM
rz_racer_69's Avatar
Old and dangerous
Thought I would run this by the collective mind before I start tearing into things.
My SuperHawk is making a light knocking noise for a few feet when leaving from a stop under moderate acceleration. Sounds like it's coming from bottom left. Can't hear it at idle, or when revving, or under way. Also can't hear it while loading the clutch with the front brake locked, and lugging the engine down, so I'm guessing it is drivetrain.
Chain is adjusted, but near the end of its life and reaching the replace-me adjuster marks. Other than needing more regular adjustments, the chain doesn't appear to be defective.
Is it likely the sound is only the old chain clicking on the stock front sprocket?
Thanks for reading.
Old Aug 2, 2014 | 08:17 AM
rick's Avatar
rick is on a distinguished road
see if chain has tight and loose spots. I chain is near end of life and there are stiff links it can make a clicking sound.
Old Aug 2, 2014 | 08:18 AM
Wicky's Avatar
More than likely what rick says above - though could be airleak pulses from the exhaust if a gasket has gone which can sound like a 'clicking' noise.
Old Aug 2, 2014 | 08:27 AM
Old and dangerous
Thanks y'all. I agree the tight links might be causing the problem.
Old Aug 3, 2014 | 10:22 PM
Old and dangerous
Changing out the chain did the trick.
ericrosendall
Nov 25, 2009 07:30 AM
The Hawk Guy
Sep 9, 2007 12:26 AM
midijunky
May 2, 2007 05:15 PM
SuperHawkins
Mar 29, 2007 06:21 AM
05xman
Nov 2, 2006 10:27 PM
