VFR Rim
Old Jan 31, 2019 | 01:22 PM
ACE VenTRa's Avatar
VFR Rim
There is a 1990 VFR rim on ebay, does anyone which rotors will work with that rim on a VTR?
Thank you
Old Jan 31, 2019 | 01:23 PM
ACE VenTRa's Avatar
Alternatively. do any forum members have a rim for sale?
Old Jan 31, 2019 | 01:31 PM
Is it front or rear rim, VFR have a very different wheel in the rear :-) it is a single sided swing arm.
Old Jan 31, 2019 | 02:24 PM
ACE VenTRa's Avatar
Well, rotors indicates plural, which should mean front rim.
Maybe I have sss on my hawk...it has been a long January.
If I said rear would I be ridiculed?
Anyhoo, front rim please. Does anyone know which rotors will fit on the front rim of a 1990 VFR and will work on the VTR?
Old Jan 31, 2019 | 05:31 PM
Thank you
Rim, rotors, axle from a '90 VFR wont fit a VTR. Sure anything is possible, but why?
Old Jan 31, 2019 | 06:19 PM
Actually you can make it fit, but first you will have to change the wheel bearing to fit the later axle size (I did that before) and than you have to get rotors from either VFR750 same year or CBR600 F2, CBR1000F, it is an older pattern bolts and these parts are rarer and probably not in a good shape, you much better off using CBR600 F3 wheels if you interested in the style of the rim, pretty much bolt on.
Old Jan 31, 2019 | 08:17 PM
Spacers, rotor diameter and offset, possible issues with bearing and seal depth.
Why? When there are other, better combinations.
Old Feb 1, 2019 | 02:05 AM
ACE VenTRa's Avatar
Roger that,
Thx
Old Feb 1, 2019 | 02:06 AM
ACE VenTRa's Avatar
Cuz it looks most similar to the 900RR rear rim...which I would like to have on my hawk, window shopping now basically.
Old Feb 1, 2019 | 02:08 AM
ACE VenTRa's Avatar
Other VFR combo's? I'd really like the twisted spoke. Machining is not an issue, it's the least of concerns.
Old Feb 1, 2019 | 05:53 AM
OK, I get it.
A very useful tool, if you don't already know about it, is at (maybe others) Partzilla. There is a feature that when a part is clicked on you will get the part details (sometimes) and a a list of other models that the part was/is used on.
Old Feb 1, 2019 | 06:08 AM
The original 900RR rim was actually smaller diameter of 16" I can't remember the later models, CBR600F3 is the best match for front wheel, as for the rear, you can either use the CBR600F3 or CBR900RR, both match and work on VTR, just different width.
Old Feb 1, 2019 | 07:32 PM
I have rims if you need.
Old Feb 1, 2019 | 09:50 PM
F3 front, 900RR rear. The easy way to get what you want
Old Feb 2, 2019 | 04:42 AM
ACE VenTRa's Avatar
Do tell!!$?
Old Jul 28, 2020 | 01:49 PM
102dals's Avatar
ACE, how 'bout some pics?
Old Jul 28, 2020 | 02:25 PM
ACE VenTRa's Avatar
Here's mine...might be off a 900rr, not sure.
Old May 29, 2021 | 11:42 AM
102dals's Avatar
ACE,
It's a 17" right? If so, which year 900RR is this from? Love the gold BTW.
Thanks
ACE VenTRa
Jul 9, 2020 04:11 PM
RedStormJ
Sep 14, 2016 08:05 AM
stangy89
Jul 12, 2011 08:42 PM
VFR79
May 29, 2008 09:06 AM
Mr Toad
Jun 24, 2007 07:14 PM
