Valve adjustments.
Old 04-09-2009, 11:30 AM
Vega (streetfighter)'s Avatar
Vega (streetfighter) is on a distinguished road
Valve adjustments.
I dont know if the previous owner did one, kinda doubt it. The bike is running like a beast and I dont really want to fix whats not broken. Should I get one done even if the bike is running great? Almost 20k miles on the bike.
If I do need to do one about how much would it cost? There are no plastics on the bike so everything should be easy to get to.
Vega (streetfighter) is offline
Old 04-09-2009, 12:49 PM
Truckinduc's Avatar
Its really easy if you wanna check the valves yourself. If they are in spec, bolt your valve cover back up and keep riding.
Truckinduc is offline
Old 04-09-2009, 01:55 PM
+1 Shim type adjustment maintains correct valve lash for a long time.
VTRsurfer is offline
Old 04-09-2009, 02:18 PM
2nd mouse gets the cheese
Little_Horse's Avatar
yeap its inspection thats on the list every 16,000 so many times no adjustment is needed.
Little_Horse is offline
Old 04-09-2009, 05:08 PM
Can I find out how to do this in the manual? If not I dont need a detailed how to, but a brief rundown on what to do would be helpful.
Thanks fellas,
Rudy
Old 04-09-2009, 06:29 PM
Page 3-7 through 3-10 of the service manual.
that can be downloaded here:
http://www.superhawk996.net/Honda_VT...ice_Manual.pdf
or here:
http://dl.getdropbox.com/u/219618/VT...3_VTR1000F.pdf
lazn is offline
Old 04-09-2009, 08:50 PM
Thanx. I will check it out.
Old 04-09-2009, 09:08 PM
Search other threads on valve adjustment. I outlined the step by step procedure on another thread a month or so ago, or check the manual. If you are good with a feeler gauge, you can do it. Checking is pretty simple, actual adjustment requires removal of the cams to swap shims.
Old 04-10-2009, 03:24 AM
FTMS's Avatar
Just checking the valves is not that big of a deal if you are somewhat mechanical. If you need to adjust them, that takes a little more. It is still not that bad compared to an I-4. Read through the how to threads, then if you have any questions just shoot some out.
FTMS is offline
superman_006
07-24-2010 10:17 PM
storm_rider
10-04-2009 11:07 AM
01-01-2009 11:44 AM
EngineNoO9
10-12-2006 06:50 PM
ClevelandSuperhawkRumble
03-12-2005 10:23 PM
Quick Reply: Valve adjustments.
