is this normal?
Old Apr 10, 2009 | 02:23 AM
Snucks's Avatar
Snucks is on a distinguished road
is this normal?
I just got a 98 Superhawk and noticed earlier today that the
exhaust coming out of the left (clutch side) can is a lot warmer than the right. It does not appear to be swallowing any coolant. Could it be one cylinder is running a leaner mixture than the other? And if so how much does carb work cost?
Old Apr 10, 2009 | 02:30 AM
RK1's Avatar
RK1
It's normal. It's a 2 into 1 into 2 so both cylinders exhaust through both cans. There's a tab in the left side pipe which restricts flow to that side's can.
Old Apr 10, 2009 | 04:24 AM
JamieDaugherty's Avatar
This only happens during low exhaust flow situations. Once the revs build the flow equals out. This is easy to see on a cold morning. Push the bike outside and start it up, after a few seconds you'll see condensation coming out of one pipe. Rev it to about 2000rpm or so and you'll see the flow increase in the other pipe.
The idea here is that you don't care how equal the flow is between the two pipes at idle and low throttle openings, you care about WFO because that's when you need the flow.
Old Apr 10, 2009 | 08:36 AM
Snucks's Avatar
thanks a lot
Hardhead
Aug 4, 2008 10:27 AM
bluevtr
Sep 17, 2007 04:47 PM
Duck007
May 23, 2007 05:10 AM
J.J.
Oct 3, 2006 01:37 PM
Hawk I Fan
Jan 13, 2005 01:53 PM
