Unusually High Idle RPM
Old Sep 16, 2010 | 05:33 AM
amhsraptor's Avatar
amhsraptor is on a distinguished road
Last night I went for a ride and my bike started up fine and was running normal except I noticed the idle was around 1500-1600 RPMs. I believe that is the normal idle range but my bike was idling from 1000 to 1100 on Tuesday. I tried pulling the choke to see if it had gotten caught and it didn't do anything and I am not sure what it could be. Bare in mind I am not a carburetor guy so I am still learning, and when I did a search I didn't see that many relevant topics.
For a little background information, I was using my bike to commute about 50 miles, both ways, a day since August 16th until yesterday when my truck was fixed.
Thanks in advance,
-BA
Old Sep 16, 2010 | 05:56 AM
nath981's Avatar
well reach under the tank from the right side and turn the plastic handled idle screw counterclockwise and get your idling back to 1000.
Old Sep 16, 2010 | 06:00 AM
Usually a high isle like that is the result of an airleak somewhere... Check all vacuum lines...
Old Sep 16, 2010 | 06:04 AM
amhsraptor's Avatar
Will do, what normally causes the idle screw to move/an airleak to occur? I am just curious because the other day it was running just fine. Could my bike is jealous of my truck?
Old Sep 16, 2010 | 06:08 AM
Nothing causes the screw to spontaneously move... Airleaks are mostly caused by dried out old hoses...
Old Sep 16, 2010 | 06:09 AM
nath981's Avatar
i think you may have hit on something here.
Old Sep 16, 2010 | 07:55 PM
Could also be sticky, kinked, or misadjusted throttle cables. be sure they have the proper slack when turning the bars lock to lock.
Old Sep 16, 2010 | 08:21 PM
As it just happened overnight I would also have to believe it was a hose that split and caused a vacuum leak.
Old Sep 16, 2010 | 08:24 PM
Or a carb fart blew it off.
Old Sep 17, 2010 | 04:19 AM
loserbaby's Avatar
jet wrench
loserbaby is on a distinguished road
air leak, failed hose IS most likely.
Old Sep 17, 2010 | 06:25 AM
trinc's Avatar
choke has no effect when pulled, i'd start by looking there.
maybe the tension adjustment... ?
tim
thedeatons
Jun 21, 2015 09:11 PM
Ziander
Apr 30, 2014 12:14 PM
meanhawk98
Feb 14, 2012 08:08 PM
john
May 28, 2010 12:48 PM
DaxMiddler
Apr 28, 2006 03:22 AM
