Two small issues. Clutch maybe and R&R???
Old May 14, 2012 | 07:58 PM
eersfanpilot's Avatar
New Hawk Rider
eersfanpilot is on a distinguished road
Ok.
Issue One: From a dead stop at a light in 1st gear and going into 2nd, or until a higher speed is achieved (maybe 20-30mph), I get a sound that is hard to describe. Usually it is very noticeable before the bike is all the way warm and before the clutch is all the way out moving from a dead stop. I would not call it a tick, or knock, but sounds more like a slap/clack?? Like I said, hard to describe. Once warm, (above 150 or 160) it seems to go away. I am thinking maybe clutch related but wanted to get opinions. Other than that, after doing the manual CCT's, baffles, TPS, and carb sync, she is purrrrrrring like a kitten!
Issue Two: Any time the bike happens to stall out, or take a few cranks to start early in the morning it blanks out the Trip and Clock on the digital gauge. I had an R&R on my previous SH go out but it just died and left me stranded. Is this R&R related, or battery?
Old May 14, 2012 | 08:07 PM
The first issue sounds more like a CCT adjustment. Did it start after you installed the manual tensioners? Because it sounds like they are loose until the bike warms up.... which is kind of how they are supposed to be or maybe a touch to loose.
The second issue sounds like the battery is low. Have you checked the voltage? Also you might want to check (and clean) all the grounds.
But if the battery is low, well then yes the R\R might be on its way out....
Old May 14, 2012 | 09:04 PM
New Hawk Rider
Edit: It has made the noise I am talking about since before the manual swap.
I adjusted the front CCT just this weekend because I thought it was sounding like it was too loose. I was getting a bit of a ticking on acceleration. Now it only makes the noise between 1st and 2nd and only at the middle to end of letting the clutch out. It does not make any sounds in any other gear, including neutral. Since the most recent adjustment it seems to be running better than ever once fully warm.
The battery sounds about right for the second issue. It has been getting progressively harder to start.
Old May 15, 2012 | 01:47 AM
GTS's Avatar
GTS
Seasoned tech
How high do you rev the engine while you're letting the clutch out?
Old May 15, 2012 | 03:40 AM
CrankenFine's Avatar
Originally Posted by eersfanpilot
Ok.
I notice a similar noise on mine when cold, pretty much when letting out the clutch in first from a dead stop. I presumed it's my fault for not being smoother on the let-out & rev-management. But in my case, I think it's new since I adjusted MCCTs recently. It goes away once fully warm though so I am basically just monitoring the noise for now.
Old May 15, 2012 | 08:47 AM
New Hawk Rider
Off the top of my head I am not sure. I do not gun it from a stop and I do not ride the clutch. I am a pretty relaxed rider and just try to leave smooth without riding the clutch.
Old May 15, 2012 | 10:27 AM
GTS's Avatar
GTS
Seasoned tech
I know mine, an the one I had several years ago, would feel grabby and chattery if you rev it to much when letting the clutch out like if you are trying to start off real fast, like a race start or something, and rev it higher than normal. Not sure if that's what you're running into or not.
Old May 17, 2012 | 04:13 PM
New Hawk Rider
Ok. So I made sure and looking at my tach when I was leaving a stop today. From stopped to first I am not going above 2k. Normally I have it out by the time I get to 2k. The noise is coming between 1200 (where my idle is) and 2k when cold. I can feel it also in my clutch lever.
Old May 17, 2012 | 06:01 PM
RWhisen's Avatar
Former Superchicken Owner
Sounds like the CCT is not adjusted correctly since the sound goes away when warm.
Old May 17, 2012 | 07:32 PM
New Hawk Rider
You and Hawk are both saying the same thing. I will give the front another small turn and tighten it up a bit more tomorrow and see what happens.
Maybe I will tighten them both down a snug more and see? The ones from superdutyd come set up to be safety wired. Once i get them set and if this noise goes away I will do that as well.
Old May 17, 2012 | 07:37 PM
Have you had the slave cylinder off lately or ever?
I have seen the push rod get bent from improper installation. I don't know if it would cause the noise you are talking about but as you can feel it in the clutch lever I don't think it's the CCT and you did say it was doing it before you installed them.
So it is something clutch related but thet are pretty tough on these bikes.
Also what kind of oil are you running, this bike is a little picky on what you run in it.
Old May 17, 2012 | 08:04 PM
New Hawk Rider
To be honest, shamefully, I have not changed the oil since I bought the bike from the previous owner. It has been on my to-do list but keeps getting over looked. I have never had the slave cylinder off. Is there a write up for inspecting? What are you oil recommendations?
Old May 18, 2012 | 01:02 PM
RWhisen's Avatar
.......What are you oil recommendations?
This could be part 2 of the trifecta!
I didn't know you had never changed your oil..........
Old May 18, 2012 | 04:27 PM
Well that is a really loaded question....lol
If you are asking what oil I use, well it's the Mobil 1 motorcycle 10-40 because my bike shifts better with it than the others I have tried. You can also use stuff like Rottela or some of the Mobil 1 that you can get at places like Wal-Mart.
In your case, as you have questions about the clutch and all that, if it were me, I would just get some Honda GN4 and a new filter (once again many options here and before you ask I use the purolator 14610 on mine) but here is the thread with the filter cross reference https://www.superhawkforum.com/forum...erencing-7884/
Old May 18, 2012 | 04:37 PM
New Hawk Rider
Thanks. I adjusted the CCT's today and they ended up being too tight. I adjusted them again and they are fine now. The sound is still there and was there even when they were too tight.
I re-shimmed the Carb like we discussed through PM and that seems to have gone well. I will give it a few days to figure out if it took care of the backfire on decel any more than it was already. I have the PAR blocked off and the carbs sync'ed, 2 shims in the back and 1 in the front. It pulls a lot harder now it seems, could just be me with wishful imagination??
I have to go to recurrent training for my plane back in ATL for a week so I will start to tackle the oils and such once I get a chance whenever I am back home. Thanks for all the help guys!
Old May 18, 2012 | 04:49 PM
Sounds like you are getting the carbs closer and by what you told me in the PM you were still lean, so upping the rear needle did give the bike more fuel, therefor you have more power..... it's not just you
Now you also see why I say to go one shim higher on the rear needle than the front.... it really works and the tip is actually straight from HRC
Old May 18, 2012 | 04:50 PM
Also don't worry about pulling the slave cylinder until after you do the oil change. I have a feeling that just changing the oil will "fix" most, if not all, the issues with the noises you are hearing
Old May 18, 2012 | 06:26 PM
New Hawk Rider
Thanks Mike. It's all the info you guys provide that makes this site so great!
quillinsmat
Sep 12, 2014 09:01 PM
Renderw
Sep 9, 2012 07:19 PM
uchi
Aug 16, 2010 11:28 AM
Otto Man
Mar 3, 2009 11:56 PM
duran
May 24, 2007 10:26 PM
