Turn Signal Flasher Relay Wiring
Old Jul 19, 2008 | 04:12 PM
Erik S.'s Avatar
I did search. I found some good info, but not what I was looking for.
I put on Motrax Arrow LED turn signals.
I also bought a Motrax Universal Flasher Relay.
My problem is, the relay comes with only Black and Red wires. While the stock relay has 3 wires; White/green stripe, Gray, Green.
From the reading, one of them is power in parallel for the brake lights, correct?
So is it safe to assume that I can put green to black, and combine White/Green and Gray to red?
If not, who has info on a LED flasher relay that is a direct plug in for Honda.
Thanks.
Erik
Old Jul 19, 2008 | 07:33 PM
Gregw's Avatar
That would be bad (but not horrible). Flasher red to white/green on harness. Flasher black to grey on harness. Leave green on the harness unconnected.
Old Jul 19, 2008 | 08:31 PM
Erik S.'s Avatar
So green isn't the ground in this case. Ok. Thank you Greg, I was not going to cut any wires until I knew where they went.
Erik
Old Jul 19, 2008 | 08:40 PM
Gregw's Avatar
Green is the ground. White/green from the harness is hot, grey outputs to the signal switch. Not really sure why the new flasher doesn't need a ground, but that's the way mine is wired and it worked.
ttocsmai
Nov 9, 2010 08:51 AM
Texassuperhawk
Oct 31, 2010 11:02 AM
johnclopp85
May 27, 2009 08:23 PM
chickenstrip
Jun 4, 2008 12:18 PM
Les
Feb 12, 2006 12:23 PM
