Troubles
Old Oct 5, 2007 | 08:42 AM
Syclone's Avatar
Boosted
Troubles
Today I rode the 'Hawk for maybe 20 mins, with three different starting instances. Didn't notice anything amiss until I was headed home, she wouldn't rev worth a crap under 4k, and it was rapidly deteriorating. I finally had to pull into the turning lane and off onto a side road, where the bike just died. I didn't notice any lighting or gauge problems, so I shut the ignition off and back on, and rode it home just fine.
I did the carb-washer mod last night, but I'm pretty sure I got all the lines hooked up right. Is my R/R going out? I did some searching but I'm still not sure what the problem is/could be.
Any help is appreciated.
Old Oct 5, 2007 | 09:10 AM
Involute's Avatar
Utardian Extraordinaire
Involute is on a distinguished road
Sure sounds electrical to me. I'd pull out a Mulitmeter and start diagnosing before I started the bike again. Hopefully it's just the battery making it's way to the great beyond.
Old Oct 5, 2007 | 10:30 AM
RickB's Avatar
Sounds more fuel related to me since it started back up fine without a jump would suggest the battery is ok. could be other electrical like the tps sensor plug loose though. check the voltage at rest and while running (do a search for the values you should see at what RPMs)
Old Oct 5, 2007 | 11:24 AM
filter69's Avatar
Thats Mr Dill hole to you
Did you just fill the tank ? i filled mine up one day and went riding and did some hard take offs and corners and flooded out my bike when i clogged the tank vent with gas ( i over filled it ) stopped the bike and waited 2 min then it was fine
Old Oct 5, 2007 | 11:49 AM
Involute's Avatar
Doh!
I overlooked that part.
I took a Dick Carnegie reading comprehension course years ago. I guess it's time for a refresher.
At least the Dick Carnegie Memory Course I took is still with me.
Old Oct 5, 2007 | 04:27 PM
Thumper's Avatar
+1
Old Oct 5, 2007 | 06:05 PM
VoodooDog's Avatar
VoodooDog is on a distinguished road
involute, OMG...
that avatar always surprises me...
Old Oct 5, 2007 | 07:07 PM
I think it's cute! I would like to introduce that image to my x. Then she couldn't acuse me of being ugly.
Old Oct 5, 2007 | 08:25 PM
Did you hook up the vacuum line to the petcock correctly?
Old Oct 5, 2007 | 08:33 PM
gboezio's Avatar
Yeah, did you reversed the 2 small hoses ?
Old Oct 7, 2007 | 01:24 AM
Syclone's Avatar
Boosted
Pretty sure both lines are correct, and I had filled the tank recently, but it wasn't overfull and I'd put 10-20 miles on it previous to this sputter
Old Oct 8, 2007 | 11:33 AM
Syclone's Avatar
Boosted
Update: I'm a dumbass, and hooked the vent line to the BOTTOM of the petcock instead of the rear, where it goes....
Old Oct 8, 2007 | 12:46 PM
RickB's Avatar
Well at least it was an easy fix....
Old Oct 8, 2007 | 12:58 PM
Standard SH reply #1
Old Oct 8, 2007 | 07:50 PM
PVLIR syndrome. It's like herpes around here, eh?
Old Oct 8, 2007 | 08:06 PM
Does that mean we need to do a vacuum line short arm inspection......
Old Oct 8, 2007 | 08:22 PM
I was referring to type II....
Old Oct 8, 2007 | 08:32 PM
Just checking for the troops.....
dudeitscristhian
Feb 22, 2016 02:43 AM
Unzie57
Oct 22, 2012 06:30 PM
krongsak
Dec 1, 2009 08:10 PM
chadcs
Aug 24, 2005 03:56 PM
devilisht2003
Jun 12, 2005 07:50 PM
