Troubles
Today I rode the 'Hawk for maybe 20 mins, with three different starting instances. Didn't notice anything amiss until I was headed home, she wouldn't rev worth a crap under 4k, and it was rapidly deteriorating. I finally had to pull into the turning lane and off onto a side road, where the bike just died. I didn't notice any lighting or gauge problems, so I shut the ignition off and back on, and rode it home just fine.
I did the carb-washer mod last night, but I'm pretty sure I got all the lines hooked up right. Is my R/R going out? I did some searching but I'm still not sure what the problem is/could be. Any help is appreciated. |
Sure sounds electrical to me. I'd pull out a Mulitmeter and start diagnosing before I started the bike again. Hopefully it's just the battery making it's way to the great beyond.
Sounds more fuel related to me since it started back up fine without a jump would suggest the battery is ok. could be other electrical like the tps sensor plug loose though. check the voltage at rest and while running (do a search for the values you should see at what RPMs)
Did you just fill the tank ? i filled mine up one day and went riding and did some hard take offs and corners and flooded out my bike when i clogged the tank vent with gas ( i over filled it ) stopped the bike and waited 2 min then it was fine
Originally Posted by RickB
(Post 132222)
I overlooked that part. I took a Dick Carnegie reading comprehension course years ago. I guess it's time for a refresher. At least the Dick Carnegie Memory Course I took is still with me.;) |
Originally Posted by filter69
(Post 132230)
involute, OMG...
that avatar always surprises me... |
I think it's cute! I would like to introduce that image to my x. Then she couldn't acuse me of being ugly. :crackup::crackup:
Did you hook up the vacuum line to the petcock correctly?
Originally Posted by 8541Hawk
(Post 132277)
Originally Posted by gboezio
(Post 132279)
Yeah, did you reversed the 2 small hoses ?
Update: I'm a dumbass, and hooked the vent line to the BOTTOM of the petcock instead of the rear, where it goes....
:oops: |
Well at least it was an easy fix....
Originally Posted by Syclone
(Post 132465)
:oops: |
(Post 132277)
PVLIR syndrome. It's like herpes around here, eh? :rotf:
(Post 132531)
I was referring to type II.... ;)
(Post 132547)
