trans messed up after je piston install
Old Jun 27, 2013 | 12:40 AM
ryan.neumantruckservice's Avatar
ryan.neumantruckservice is on a distinguished road
I got my motor back and even before starting it i noticed i couldnt find neutral than, what i found it where 5 th gear should be and the whole line up of gears is wrong someone please need insite badly
Old Jun 27, 2013 | 12:41 AM
Im putting a hold on the check till my engine builder fixes the problem
Old Jun 27, 2013 | 12:50 AM
What im saying is maybe the dude screwed up the shift fork placement
Old Jun 27, 2013 | 04:17 AM
Maybe the end linkage is just upside down. Look at the first pic in this thread. If it looks like this (end arm that attaches to the shift gear on the bike is pointed up), then you have reverse shifting. All you need to do is loosen that 10mm bolt and flip the little aluminum arm over.
https://www.superhawkforum.com/forum...hifting-27577/
Edit:
Reverse shifting:
Stock linkage placement (different linkage, but you can see the positioning)
jefejrs
Motorcycle News
May 3, 2012 07:50 AM
WAYNEHAMMER
Mar 4, 2012 04:48 PM
uchi
Sep 20, 2010 08:54 PM
E.Marquez
Jan 11, 2009 12:46 PM
lotp
Feb 22, 2007 05:41 PM
