These settings sound good? (Carb assistance)
Old Sep 18, 2007 | 02:47 PM
Anto's Avatar
Anto is on a distinguished road
So I just rebuilt the hawk.
Settings are as follows:
Dynojet kit (drilled slides & shortened springs)
K&N Filter with block off plates
Two Brothers exhaust
180f/185r mains
#45S slow
Needle on 5th clip from top (first up from bottom).
Both screws at 2.25 turns out.
Elevation is pretty much at sea level.
Emissions have been fully removed, PAIR fully disabled.
Carbs haven't been sync'ed yet, but at idle & steady state throttle I get popping and carb backfires half the time.
Should the sync fix this? Orrr should I go a tad richer on the mixture screws?
Old Sep 18, 2007 | 04:12 PM
Anto's Avatar
Just rode it. The bike has a flat spot from 3k-5k rpms. After 5k, it picks up better.
I'm going to richen the screws to 2.5 turns out. Sound about right?
Old Sep 18, 2007 | 05:14 PM
redman's Avatar
Depends on how much throttle you are giving it when it goes flat and how it behaves when it's going flat. If it's 3-5K andjust off idle then maybe...if it's flat at 1/3 to 3/4 throttle then it's needle/clip position. Does it go heavy/boggy flat or light/airy flat?
Old Sep 18, 2007 | 10:13 PM
I ran a Dynojet kit back in '98-'99 and I don't remember the needles being pulled up that high. I think you were supposed to start with the clip one down from the top not one up from the bottom. With the needles up that high you should be running extremly rich.
Old Sep 18, 2007 | 11:03 PM
Anto's Avatar
Dynojet manual specs needles 5th clip from top with a aftermarket exhaust & k&n filter.
I'm going to go for the .5 turns out & see what i'm at.
The bogging is light/airy flat, lean condition indeed.
Old Sep 19, 2007 | 09:16 PM
TBR full exhaust or slip-on?
If full then go with 48 pilots. Otherwise go to 2.5 turns on mixture and raise needles one notch (lower clip).
Old Sep 19, 2007 | 09:50 PM
Anto's Avatar
I'm pretty sure slipon. I just changed to a high mount.
The bike pulls well when I give it full throttle, but at low end and midrange, it sputters, hesitates and kicks. I forgot to add that I had installed a rear emu tube in the front, which i'm going to remove and replace with the correct front emu tube.
If that doesn't yield good results, i'm going to move the needles down another notch, to full rich.
The previous owner ran this on the 6th clip with good results, however he didn't seal the airbox correctly. I went back & resealed everything.
Current settings are listed up top, but the carbs have been sync'ed and the screws are at 2.5 out.
What I don't get is why the carbs are sputtering and popping SO much. I correctly removed emissions, diabled PAIR and sync'ed the carbs, and it's still popping like crazy. Lean condition?
BTW, is it alright to merge the two sync vacuum lines into a y fitting and cap that off? Or should I keep them capped seperately?
Old Sep 20, 2007 | 09:56 PM
trinity012's Avatar
Hi Anto, did you check w/all hoses where they disconnected and cap off, and why do you want to route them like Y before cap them off? in order to diable PAIR make sure you bought this part (16214-MB0-000) and small clam (auto part) secure it w/right side of vacuum hose (auto part) that how i did mine. Good luck anyway did you search all thread for DIABLE PAIR AND GREG,S HONDA WEB SITE.
Old Sep 20, 2007 | 11:13 PM
NO, it is NOT okay to merge the two vacuum lines. The front should be plugged with the small allen screw. The rear should have a stock fitting which holds a line that goes to the REAR nipple on the petcock.
Old Sep 21, 2007 | 01:52 AM
Anto's Avatar
PAIR disablement consisted of the capping of the open airbox holes, the entire system removed, the carb tubes capped & and the two holes on the valve cover capped off with a rubber cap.
For the carb sync, the previous owner had installed a rear brass nipple fitting on the front cylinder, so I just covered it with a rubber cap.
I removed the Y fitting, the rear carb sync line is going to the rear of the petcock.
I'm going to tear into the carbs again tommorow, i'll post status.
Old Oct 3, 2007 | 10:44 PM
Anto's Avatar
Alright.
To recap:
Moved the carbs to 2.25 turns out, needle on 5th clip
The bike runs 100% better with the choke pulled out.
Planning to enrichen needles another notch (full rich).
I find this odd, as I haven't heard of anyone running full rich on the hawk on a dynojet kit..
Old Oct 4, 2007 | 08:18 PM
twstd99's Avatar
twstd99 is on a distinguished road
did you take the high and low speed jets out along with the mixture screws and clean the carbs out with compressed air? also check your floats? do you still have the airbox snorkel on?
Old Oct 5, 2007 | 10:37 AM
Anto's Avatar
Check,
& the airbox snorkel is still on.
Old Oct 5, 2007 | 11:05 AM
trinity012's Avatar
Hi Anto, from what i understand w/re-jet (Fac-pro 50) i set them at 4th notch down (from tip) mixture screw out almost 3 turn, K-N air filter, i dont plug cams cover breather hoses (the 2 big one that run into a air box) in your case it seems like you need to enrich your mix ture screw to 3 full turn and stay at 5th and try see how it work for you. Good luck, before i completed 2nd time re-jet my dyno run at 105 hp and 65 hb.
Old Oct 5, 2007 | 04:33 PM
Thumper's Avatar
+1 on the 48's on the SuperHawk, that is what most tuners miss. 45's too small and the 50's are too big.
Old Oct 7, 2007 | 04:56 AM
hymey's Avatar
hymey is on a distinguished road
48 pilots could help. I would go to the 6th clip first. Its happening around 3000rpm not idle. The slides start raising as soon as you blip the throttle. Like 1/8 throttle!
I found the DJ needle lean on clip 5.
Pull the tank off and the air box. (with engine warm). Start it and watch the slides they start opening immediately. It will pop with no filter so give it some choke. While ur at it grab a piece of plastic flexible hose about 2 inch round. Put it to each carb and listen. You will hear which cylinder is pulling more air. You can roughly sync ur carbs this way b4 fine tuning with gauges.
Try clip 6. I think u will find 45 pilots good with 2.5 turns. Just make sure it doesnt pop on overun otherwise run 48s.
Cheers
Joel
Old Oct 21, 2007 | 08:09 PM
Anto's Avatar
Alright.
Installed #48 Pilots, bike runs much better compared to what it ran like before.
A/F Screws are 2.25 turns out, needles on 6th clip. Still 180f 185r. TPS is set at ~650.
The bike still jerks at steady state throttle on the freeway! There is jerking & a loss of power, then it pulls again, then it cuts out again. I have to continuously accel/decel to keep speed.
I also hear some popping at high RPM on decel, are the mains STILL too lean? Should I bump it up to 185f 188r?
Old Oct 21, 2007 | 11:30 PM
killer5280's Avatar
The Dynojet instruction sheet for this kit recommends 185f/190r and needle clip on the 5th notch as a starting point for a VTR with a slipon and a K&N filter. You're getting close to that now.
The K&N filter is really a lot less restrictive than the stocker and needs much larger jets--much larger than you think it will. I have one and my bike ran so poorly with it that I took it out until I can devote more time to getting it sorted out.
Old Oct 25, 2007 | 03:27 PM
Anto's Avatar
SEXY
Got around to changing some settings.
185f 188r
#48 slow
Dynojet on 5th clip
Screws 2.5 turns out.
ART high mounts, K&N Filter
Bike PUSHES.
Initially I had it on 2.25 turns out, but had some excessive popping on overrun 70% of the time.
Increased the screws to 2.5 out and the frequency of the popping went down. It still pops on overrun, just not as much. I'm sure it'd be solved with a 190r, but i'm satisfied with my current settings.
Thanks guys!!
CruxGNZ
Mar 23, 2016 10:21 AM
996Riders
Jun 16, 2010 05:53 AM
Just_Nick
Sep 3, 2009 06:19 PM
Reason
Aug 18, 2008 04:58 PM
georonimo
Aug 27, 2006 09:45 PM
