Thermostat removal wo tank lift?
Old Sep 28, 2019 | 12:07 PM
Havent done this in 5 yrs can I sneak the thermostat out wo removing the airbox?
Old Sep 28, 2019 | 12:34 PM
I suppose if you had to, and had tools to reach hard to get to fasteners, but honestly I think you will spend 10 times the time to do that way then remove the tank and air box
Old Sep 28, 2019 | 12:55 PM
CaryDG's Avatar
You do know that the tank can be tilted back without disconnecting any lines, right? Remove the seat, the 2 bolts behind the steering head and tilt her back. A few screws, a couple of breather lines on the air box and you're wide open
Old Sep 28, 2019 | 12:59 PM
Wicky's Avatar
Pat Pending
Old Sep 28, 2019 | 06:28 PM
Ok so yeah it one of those jobs that you wonder if the shortcut is longer than the long way.
BUT
I did it with the tank & air box in place! The trick is the back bolt on the housing. You can do it with a quarter inch socket but I used this awesome too called the Tite reach. It transmits socket torque thru it so you doing need to swing the ratchet in tight quarters. It has saved me on the bike and truck many times.
https://www.ebay.com/itm/Tite-Reach-...4AAOSw5dlaFJjo
So new thermostat is in, took off water pump cover and all looked good. No restrictions in hoses and the coolant was super clean. Almost shockingly so.
No obstructions for air flow to the rads. Now I will see if the cooling capacity changes.
Oh and water pump impeller spins fine.
josh2025
Sep 27, 2009 09:42 AM
Pitt3265
Aug 11, 2009 06:02 AM
filter_jam
Apr 15, 2007 12:52 PM
SuperHawkins
Feb 12, 2007 09:51 AM
Les
Feb 5, 2006 06:31 AM
