replacing air filter
Old Feb 4, 2006 | 09:19 PM
Les's Avatar
Les
Les
The first step in the Honda service manual when replacing the air filter is to remove the gas tank. I started to do this and then realized that access to replace the air filter was clear when I removed the front two bolts and lifted the front of the tank up. I would not recommend removing the tank to replace the air filter.
Old Feb 4, 2006 | 10:12 PM
BirdofParadise's Avatar
BirdofParadise is an unknown quantity at this point
Re: replacing air filter
True!
Removing the seat and using a small piece of 2X4 to hold up the tank from underneath, allows plenty of access to remove the screws and the air box cover.
Easy
Old Feb 5, 2006 | 06:31 AM
another practical suggestion:
wait until your gas tank is low on fuel, remove the two front bolts, then use a tie-down (I use the cheap elastic type) and lift the tank up by anchoring the tie-down at the front of the tank and a roof rafter. The advantage here is that there is nothing in the way as you work at removing the airbox cover screws.
cheers
Mikstr
trinity012
Jun 9, 2007 08:46 PM
filter_jam
Apr 20, 2007 07:05 AM
filter_jam
Apr 15, 2007 12:52 PM
ali_squidz
Apr 2, 2007 06:27 PM
xecutech
Apr 2, 2007 10:00 AM
