Tach fritzing
Old Apr 13, 2015 | 08:38 AM
Tach fritzing
So this is a strange cause and effect. I installed a brand new battery and in the next few days my tach has begun to not work intermittently. Then my digital thermometer.
These could be unrelated but could a slightly larger battery (YTX 14BS) do this? Seems unlikely or unrelated but has anyone had this happen before I start tracing wires?
Seems too coincidental to be a coincidence.
Old Apr 13, 2015 | 09:00 AM
thetophatflash's Avatar
How's your R/R?
Old Apr 13, 2015 | 09:27 AM
R/R is recently replaced and I have 2 voltage meters that are reading good charge rates. I will double check its connections now that you mention it and put an outside voltmeter to check.
Old Apr 13, 2015 | 10:01 AM
Update: Voltage is 13.2 standing and 15.7-15.8 running measured across battery.
That sounds too high to me.
UPDATE 2 I swapped on my backup RR (also an R1 unit) and the running voltage went to 16.5-16.6.
BUT, the tach came back on so at least I can (sorta) rule out bad connnections.
The different volts could easily be due to me sanding the contacts when re-installing the ground.
Old Apr 13, 2015 | 04:02 PM
Well, this is a one sided post but the latest finding is that all is normal with the new RR.
One more proof that it pays to keep a regulator rectifier in stock just in case.
Old Apr 13, 2015 | 04:53 PM
Glad to help out. lol
Old Apr 13, 2015 | 04:59 PM
Yeah, kind of like when I ask my wife where my glasses are when they are on my head.
I still think its just the clean ground wire that did it. Still want to do that free ground upgrade mod.
Old Apr 13, 2015 | 05:48 PM
Soooo, you're leaving it as is @ 16+?
See post 133.
Old Apr 13, 2015 | 07:50 PM
Well, sorta. That reading is with an actual multimeter.
I have 2 other voltmeters on the bike and they are reading around 14's. I am going to do some tinkering tomorrow to get a better sense.
I don't love the idea of a true 16volts, but don't think it is. Will try other meters I have.
Old Apr 15, 2015 | 07:29 PM
Try a quality known good meter (tested against a known source voltage.)
16+ volts is in the destroy 12VDC components range
You either have a bad R/R if you really are getting 16v DC, OR you have a bad meter
smokinjoe73
Jul 14, 2007 08:49 PM
FordsnRebels
May 8, 2007 10:10 PM
wardo996
Mar 21, 2007 10:20 AM
calitoz
Sep 18, 2006 02:42 PM
mamisano
Apr 3, 2005 12:41 AM
