Tach fritzing
Tach fritzing
So this is a strange cause and effect. I installed a brand new battery and in the next few days my tach has begun to not work intermittently. Then my digital thermometer.
These could be unrelated but could a slightly larger battery (YTX 14BS) do this? Seems unlikely or unrelated but has anyone had this happen before I start tracing wires?
Seems too coincidental to be a coincidence.
R/R is recently replaced and I have 2 voltage meters that are reading good charge rates. I will double check its connections now that you mention it and put an outside voltmeter to check.
Update: Voltage is 13.2 standing and 15.7-15.8 running measured across battery.
That sounds too high to me.
UPDATE 2 I swapped on my backup RR (also an R1 unit) and the running voltage went to 16.5-16.6.
BUT, the tach came back on so at least I can (sorta) rule out bad connnections.
The different volts could easily be due to me sanding the contacts when re-installing the ground.
Yeah, kind of like when I ask my wife where my glasses are when they are on my head.
I still think its just the clean ground wire that did it. Still want to do that free ground upgrade mod.
See post 133.
Well, sorta. That reading is with an actual multimeter.
I have 2 other voltmeters on the bike and they are reading around 14's. I am going to do some tinkering tomorrow to get a better sense.
I don't love the idea of a true 16volts, but don't think it is. Will try other meters I have.
16+ volts is in the destroy 12VDC components range
You either have a bad R/R if you really are getting 16v DC, OR you have a bad meter
wardo996
Mar 21, 2007 10:20 AM
