Swing arm pivot nut
Old Jun 10, 2014 | 02:08 PM
Kendrick's Avatar
The Hypno-Toad
Swing arm pivot nut
Okay in my on going ordeal I need to replace my left foot rest bracket. How do I remove the swing arm pivot nut? Is this just a brute force thing, or is there more to it?
Kendrick
Old Jun 10, 2014 | 02:15 PM
Righty tighty, lefty loosey.
Old Jun 10, 2014 | 02:22 PM
rick's Avatar
rick is on a distinguished road
Just apply force in the normal loosening direction. It's tightened down pretty hard. I always use a cheater bar to help. Yow may need to hold the bolt with a wrench from the right side too.
Old Jun 10, 2014 | 02:25 PM
1/2-inch drive sockets are best as it's torqued to 69 F#, so stiction makes it tough to budge. Be thankfull its not the right side footpeg bracket you need to replace because then the pivot bolt has to then come out too (remove the rear wheel and tape the threads on the axle bolt to use to "drive" out the SA pivot bolt)!
Attached Thumbnails Swing arm pivot nut-20140329-vtr-status.jpg   Swing arm pivot nut-20140329_152433.jpg   Swing arm pivot nut-20140524_120258-0-.jpg   Swing arm pivot nut-20140524_115903.jpg
Old Jun 10, 2014 | 02:55 PM
Kendrick's Avatar
The Hypno-Toad
I know...if it were the right side it would just stay bent, but since I thought the left side would be easy, here we are.
Old Jun 10, 2014 | 05:14 PM
thedeatons's Avatar
Air compressor, impact gun, sockets. Off in 5 seconds.
James
Old Jun 10, 2014 | 07:42 PM
Actually, you can use my garage if you want. I have all the tools you need. Just drop me a PM.
Old Jun 10, 2014 | 09:56 PM
SIRR1's Avatar
Deals Gap is a Hoot!
SIRR1 is on a distinguished road
Swing Arm Bolt
One thing I learned when building my XR400R into a Street Motard is that when purchasing any dirt bike or dual purpose bike take along a ratchet set to try and move the swing arm bolt.
If you can't rotate the bolt (not the nut) in the swing arm there is a rust, lack of maintence problem with the bike and run away quickly or try and get the bike at a much lower price.
CRF-X, CRF-F, CR, XR, XL's are notorious for seized swing arm bolts and are a real bitch to remove.
I have seen CRF450X owners cut the swing arm bolt at the frame to remove the swing arm and toss it in the trash in order to save the bike!
Using a press to push out the bolt works sometimes if not the swing arm is junk, it seems to be an electrolysis problem between the aluminum and the hardened carbon steel swing arm bolt fusing in the middle of the swing arm steel spacers.
With the Hawk having a aluminum swing arm you may want to do this before buying the bike.
SIRR1
Old Jun 11, 2014 | 06:55 AM
Kendrick's Avatar
The Hypno-Toad
Just used my torque wrench as an untorque wrench lol.
Problem solved
skokievtr
Jan 4, 2014 05:38 PM
bump_evl
Aug 3, 2006 06:35 AM
evil-kev
Jun 28, 2006 09:13 AM
evil-kev
Mar 14, 2006 10:46 PM
