Suzuki 250LT Quad Runner 1995
Hello gentlemen, I'm a novice here. I'm attempting to rebuild the carb on a Suzuki 1995 LT 250 Quad Runner. Anyways, I was attempting to put the carb back in and I broke a white plastic valve stem. It has a little copper pipe inside of the white stem, the metal broke off inside. Anyways, does anyone know if there is a replacement part for this valve or I can replace the metal inside it? I was able to remove the broken piece of metal from the carb but not sure about removing it from the white plastic piece. Thank you in advance for any help.
