logan5840 |
03-20-2024 05:09 PM |
Suzuki 250LT Quad Runner 1995
Hello gentlemen, I'm a novice here. I'm attempting to rebuild the carb on a Suzuki 1995 LT 250 Quad Runner. Anyways, I was attempting to put the carb back in and I broke a white plastic valve stem. It has a little copper pipe inside of the white stem, the metal broke off inside. Anyways, does anyone know if there is a replacement part for this valve or I can replace the metal inside it? I was able to remove the broken piece of metal from the carb but not sure about removing it from the white plastic piece. Thank you in advance for any help.
https://cimg3.ibsrv.net/gimg/www.sup...996e3fc2e.jpeg
